Spyder Auto Tail light issue
Hey guys brand new Porsche owner here! I have a 2001 911 cabriolet that I just installed a pair of Spyder auto tail LED tail lights into. I blew the a4 7.5 fuse out when I first installed the lights, and now when I turn my headlights on my brake lights dont get brighter when i hit the breaks. It works fine with my headlights off so I do not think its the break switch. Everything else works perfectly! Please help!!!
Received 1,185 Likes
No relay. Fuses. If you blew a fuse then something is wrong. LED lights are polarity sensitive, meaning the + and - connections make a difference in whether they work or not. You need to carefully check the wiring and bulbs in your new "brake" lights. Do all the other lights work...turn signals, parking lights, four way flashers, etc.?
Captain Obvious
Super User
Super User
Not to be picky (too much) but cars have "brakes" not "breaks". It helps a lot when you get the terminology correct. That being said, what IM000 said, check the entire tail light system with a multimeter. Something is wrong.
So if I had a multimeter what should I be looking for? Might need to make a stop at a autozone to borrow one
Captain Obvious
Super User
Super User
RT_955TT_KY (04-08-2020)
