996 Forum 1999-2005
The "Ultimate AOS Solution"
Old Apr 17, 2020 | 08:24 AM
  #466
Kris Murphy's Avatar
Kris Murphy
Originally Posted by Porschetech3
Hi Noz, part #6 has the pop-off valve on it IF it's a 996.1 or early 2002, if it's a late 2002 or 996,2 it has a 2 bolt elbow with no pop-off valve.. Early models has 1 bolt, late has 2 bolts and cannot b
e retrofitted.
Skip - #2 on this diagram. Is that the gasket that comes with the AOS. I'm pretty sure it is, but wanted to double check? I have never replaced or seen an additional gasket there (other than the one that is already on the AOS).
Old Apr 17, 2020 | 09:36 AM
  #467
De Jeeper's Avatar
De Jeeper
on the URO one i bought it has #2,10,11 just like the factory but i does look like all the aftermarket ones are not created equal. You should double check and verify before buying.
Old Apr 17, 2020 | 10:22 AM
  #468
Kris Murphy
Thanks, that is what I thought. I have had a series of the Porsche AOSs and that is how it has always come. FCP Euro has got to be tired of me sending AOSs back to them....
Old Apr 18, 2020 | 12:19 AM
  #469
Porschetech3's Avatar
Porschetech3
All the AOS's I have seen whether aftermarket or OEM has had the red rubber seal on there.
BTW your UAOS is on its way !! Shipped out today and expected to arrive Monday 4/20/2020
Since you are having issues on the track, you should check your engine health/ blow-by like described in this thread..https://rennlist.com/forums/996-foru...w-by-test.html
Old Apr 18, 2020 | 12:49 AM
  #470
TexSquirrel's Avatar
TexSquirrel
I‘m in the middle of installing mine now.
I’ve removed the AOS, and tomorrow morning I’m going to start the install.
I‘m glad I won’t have to go through this again.
I feel for those who have had to do this multiple times...unless they’re getting paid.
Old Apr 18, 2020 | 01:33 AM
  #471
Porschetech3
I know !!! I have heard of many having failed AOS's 2-3 times in an engines life, they are just lucky they didn't get a big gulp of oil all at once like some do ... We have seen that several times here lately on this forum with really bad out comes..
Old Apr 18, 2020 | 01:50 AM
  #472
TexSquirrel
And then you sold me a Üro AOS with a non-functioning diaphragm inside.
Do you know which post has the wiring instructions?
I think this thread is up to 100 bazillion posts, it’s gonna take me a couple of days to find them.
Old Apr 18, 2020 | 02:41 AM
  #473
Porschetech3
Yep, I am the only one that can sell Brand New Non- Functioning AOS's for top dollar !! Lol
The simple wiring directions are on the first post of the " UAOS install / tips/ tricks " thread.. https://rennlist.com/forums/996-foru...ps-tricks.html There is not a whole lot of posts in that thread.
Even the most bulletproof of m96 engines can fail from even a brand new Porsche AOS, Jake Raby recently had two engines with bent rods due to failed Brand New Porsche OEM AOS's about 6 months old.
The UAOS stops that kind of non-sense.
Old Apr 20, 2020 | 04:25 AM
  #474
pdxmotorhead's Avatar
pdxmotorhead
yep tested fine,, 4500 miles later boom..
Old Apr 20, 2020 | 11:18 AM
  #475
hatchetf15's Avatar
hatchetf15
Skip...another order coming at ya. Second AOS apparently failing within 5,000 miles. What crap! Unless there’s some other way the crankcase can be drawing 11” H2O with aircon off and 7” with aircon.
Old Apr 20, 2020 | 09:59 PM
  #476
Porschetech3
Bring it on !! I just put in another order/batch of the Carbon Fiber Filled Accumulators today. Schmit Proto who is doing my PA-CF Accumulators are kinda overloaded with making masks and shields for medical use for Covid 19 pandemic, promised to push my order through on time.
Old Apr 30, 2020 | 12:45 AM
  #477
Porschetech3
Only 4 slots left for the April/May UAOS batch orders !!
BTW: The URO regulator is on National Backorder (for 45-60 days) so all orders will be sent with the Vaico regulators installed untill further notice.
I have tested/evaluated the Vaico and it is approved for use with UAOS..
Old Apr 30, 2020 | 10:23 AM
  #478
TexSquirrel
Come on, you know you need one!
Having one means you don't need to buy a manometer to continually check your AOS.
The UAOS monitors that (and other things) for you.
After the UAOS is installed, if the AOS diaphragm fails, it's just a 10 minute DIY job to replace it.
Old Apr 30, 2020 | 12:39 PM
  #479
Porschetech3
We have seen so many complete engine failures lately that can be traced back to AOS malfunction !!
I am wondering how many of the "catastrophic failures" in the past that were so broken that a cause of failure couldn't be determined, or was just so bad the engine wasn't even worth opening up to inspect, just scrapped, could have been all a chain reaction of an simple AOS failure !!!!
Old May 1, 2020 | 01:27 AM
  #480
808Bill's Avatar
808Bill
Vaico made my last AOS that failed in 6 months.
