The 133,333 mile engine rebuild thread
#91
No conclusive answer. It could easily have been the AOS fitting or the VarioCam solenoid seal. Or both, or something else in that area. For me, it doesn't matter any more. For you, consider looking at the solenoid seal.
What's the story on your photo? That's not your car, is it? Looks like a good place to kick up a little dust...
#93
Just got my Manometer with no instructions or tubing, so I need to figure out how it works.
#95
https://rennlist.com/forums/996-foru...l#post16069073
#97
Well I bought my single port without realizing it. I saw another member recommend it and ordered from the link he posted. I have no idea where that thread is.
#98
Just a car guy
Post #272 and #280 show the one I bought at this old thread:
https://rennlist.com/forums/996-foru...une-up-19.html
The link is around too. I can post again, if there is interest. Seems to work well. There is no need for two nipples... well on this device, anyway. If your device has a a vent to atmosphere, that's all you need. Simplifies things, actually. Hard to take readings off the wrong nipple if there's only one.
cds72911 (01-08-2020)
#99
Damn spell checker got me again.
The Nome knows!
The device has no second port or any vent to the atmosphere...I checked all 6 sides.
#101
bar, psi, in HG, kPa, in w.c., mm Hg, mbar, mm w.c., Max Pressure 5 psig... Not sure which unit to use.
https://www.testequipmentdepot.com/d...SABEgJrHvD_BwE
#104
Bill, you only need one port. The other port goes unused (to atmosphere) for the devices that have two...
If you look at the thread I posted above, there are links to other threads someone else posted. Ahsai is the expert in this stuff. 5" of w.c. is ideal according to those threads (Tony Callas reference).
808Bill (01-08-2020)
#105
