996 Forum 1999-2005
Replacement M96 DIY engines under 10k
Old 10-29-2019, 11:14 AM
  #31
Scott at Team Harco
Just a car guy
Scott at Team Harco's Avatar
Originally Posted by Porschetech3
Nickies DIY for M96/01 /02 /04 years 99-2001
Nickies for 3.4 3.6 3.8 from LN $4995.00 (includes pistons/pins/rings/clips)
#1364363-M9601SET complete gasket set/bolts ect. from AutohausAZ $475.25
996-105-253-00 Vario cam guides from Auto Atlanta $21.66 need 2 sets
Part# 000-043-204-35-M258 Loctite 5900 from Pelican parts $14.00
Part # 996-105-170-53-M48 Iwis cam to cam chain From Pelican Parts $21.00 x2
Part# 996-105-177-53-M48 Iwis long chain from Pelican parts $56.50 x2
Part# 996-105-171-55-INT Iwis IMS chain from Pelican $28.00
Part# 996-105-175-52-M260 chain guide (primary)From Pelican parts $28.25 x2
Part# 996-105-173-52-M260 chain guide (secondary) from Pelican parts $28.50 x2
Part# 996-105-165-55-M100 IMS chain rail from Pelican parts $38.25
Part# 996-105-166-51-M100 IMS guide from Pelican parts $46.25
Part# 10-0124-125-M3020 LN/RND IMSB from Pelican parts $733.50
Part# 996-101-115-62-M100 carrier bolts from Pelican parts $6.25 x14
Part# 996-101-205-10-M100 main bearings from Pelican $ 8.25 x14
Part# 996-103-121-62-M100 rod bearings from Pelican $8.25 x12
Part# 996-101-129-52-M100 thrust bearing from Pelican $14.50 x2
Part# 900-041-004-01-OEM IMS chain guide clip $1.00
Part# 204-6301 Rod bolts from ARP $222.69
$7196.76 parts Total
$500.00 head service
$ 7696.76 + your labor
Not much more than the Factory short block, this is the way to go if you have the Skilz !!!!
Tagging for the day when I will want to find this.
Thanks, Doc (and all that have contributed).
The following 2 users liked this post by Scott at Team Harco:
MoveableBeast (06-30-2021), Porschetech3 (10-30-2019)
Old 10-29-2019, 12:26 PM
  #32
Byprodriver
Byprodriver's Avatar
Originally Posted by soverystout
I would replace all of the valve seats as part of the refurb just due to that being a mode of failure.
If it is a 2002-2004 3.6 engine
Old 10-29-2019, 05:58 PM
  #33
996.2
996.2's Avatar
This will result in more reliable 996 engines:
The following 4 users liked this post by 996.2:
808Bill (11-09-2019), steckm (11-17-2019), TexSquirrel (10-29-2019), yaz996 (10-29-2019)
Old 10-29-2019, 06:10 PM
  #34
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,290 Likes on 902 Posts
This video series specifically covers the assembly of the M9X engine. It will assist DIY and Professionals alike, with the task of assembling the M9X engine from scratch.
The following 5 users liked this post by Flat6 Innovations:
808Bill (11-09-2019), dporto (10-30-2019), steckm (11-17-2019), TexSquirrel (10-29-2019), yaz996 (10-29-2019)
Old 10-29-2019, 06:51 PM
  #35
TexSquirrel
TexSquirrel's Avatar
Received 2,425 Likes on 1,290 Posts
Woohoo Prime Video!
That way I can get it digitally, and watch it at work and at home.
Hope it's out before long so I can ask for it for Christmas...if I can wait that long.
Old 10-29-2019, 10:08 PM
  #36
Flat6 Innovations
Former Vendor
Originally Posted by TexSquirrel
Woohoo Prime Video!
Pre- sales will happen before Christmas. The finished product won't be released till late January- February.
Old 10-29-2019, 11:54 PM
  #37
pdxmotorhead
pdxmotorhead's Avatar
Originally Posted by Os7213
I remember those pads.
If my memory is good they are about 4-5 inch long and are usually 500-1000 watts.
They are peel and stick but need to be sealed with silicone.
The only problem I can see is the surface of the M96 pan is not smooth and have ridges so it might be harder to have the pad stick to it.
I do live in cold climate so we are used to see theses system either for oil pan but mostly for coolant which is a probe type heater but I never expected I would need one of those as I dont drive the car during winter months. The coldest temperature the car would see here is around 42 deg F.
Im now wondering if you heat up the oil, let say an hour before running the engine without the engine , will it release the moisture from the oil without eliminating it as it would normally if you would drive the car for an hour?
I would not leave it on that long,, I don't think they are meant for more than a pre-heat session.
The one I used had "boot hooks on 2 edges, and you laced it around the tank, it was a Moroso IIRC,
I did get to wondering if anybody has installed a pump style engine heater on a 911.. Heating the water would help too..
Would make for short warmup on a colder morning.
Os7213 (10-30-2019)
Old 10-30-2019, 12:46 PM
  #38
Cogito_Ergo_Zoom
Cogito_Ergo_Zoom's Avatar
Yes, consistent with the anecdotal experience from the Spec 996 group, which has probably been the best real world test bed for M96 motors being pushed to their limit. Keep em full of fresh oil and run em hard. (And whatever you do, don't over-rev them on the downshift, even a little bit.)
Originally Posted by Charles Navarro
I have stacks of papers published in peer reviewed engineering journals that directly point to the fact that oil has a huge part in all of this. Time permitting I've been digesting them into a condensed form which I plan on sharing, but it's been a project I've been working on the last 11 months.
Based on the available research, higher ZDDP and moly levels along with increased HTHS vis would seem to help extend the UMW (ultra mild wear) regime for aluminum bores.
A paper published by Toyota that I came across this morning indicates that sulfur in fuels and interactions at low engine temperatures below 40C create acids that cause accelerated wear in MMC bores, like Lokasil and Alusil.
Although some think it's extreme, more frequent oil changes are the best step to extend the usable life. Those cars driven in cold climates or very short distances where the oil never gets to temp are those cars that will have the highest bore and ring wear.
Old 10-30-2019, 01:09 PM
  #39
Charles Navarro
Charles Navarro's Avatar
Received 1,170 Likes on 609 Posts
Spot on. Probably helps that most, if not all of them, are running real race oils with high ZDDP and moly content, and frequent oil changes.
Old 10-30-2019, 04:04 PM
  #40
jon@ebsracing.com
Rennlist Site Sponsor
jon@ebsracing.com's Avatar
Hello Guys, Jon from EBS Racing here. Noticed the 996 engine rebuild parts list. Just for fun I ran the numbers to see where we would be. Turns out we do the same parts list at $6245.00 saving almost $1000.00. We can also build your engine if you like. If you would like to see the detailed price quote please PM or email jon@ebsracing.com
For engine rebuild questions, upgrades and big bore conversions email our engine builder don@ebsracing.com
Jon
Jon
EBS Racing
4068 S McCarran Blvd
Reno, NV 89502 USA
jon@ebsracing.com
http://www.ebsracing.com
We can answer your Porsche questions with live customer support from 8 AM to 5 PM PST M-F
(775) 673 1300
The following 2 users liked this post by jon@ebsracing.com:
dporto (10-30-2019), EVOMMM (12-02-2021)
Old 10-30-2019, 10:54 PM
  #41
Porschetech3
Porschetech3's Avatar
Received 4,631 Likes on 2,101 Posts
Jon
That's great !! Saving nearly 1k dollars on basis essential rebuild parts could mean that some DIY'ers could opt for H-beam 4340 rods or the much loved IMS Solution. If you would please copy and past your price list for ease of comparison and to archive it for potential DIY'ers, it would be much appreciated, thankx.
Old 10-31-2019, 02:21 AM
  #42
pdxmotorhead
Jon
That's pretty good, cheaper than my 2 cylinder KTM motorcycle..
Old 11-09-2019, 10:12 AM
  #43
billh1963
billh1963's Avatar
Will those of us who attended the hands on classes get a discount?
Old 11-09-2019, 10:40 AM
  #44
Byprodriver
+$200 to ship a engine case to LN
Old 11-09-2019, 10:53 AM
  #45
808Bill
808Bill's Avatar
Is that a one way shipping quote?
Don't forget the sales tax
Quick Reply: Replacement M96 DIY engines under 10k
