996 Forum 1999-2005
Metallic Chunks in Oil
Old 03-04-2019 | 09:38 PM
Flat6 Innovations's Avatar
Flat6 Innovations
Former Vendor
Pull the sump plate... Its a 20 minute job. Post pics of the sump plate without cleaning it... Use some sunlight if possible to expose the metals that are suspended in the oil that remains in the plate. Sunlight does the best job of waking these wear metals up for a photo.
With these engines one way to reduce a rod knock is to remove the oil filter element. This opens the oil volume up by 30% and the higher volume of oil will remove the noises.. This is an old trick that shady dealers have figured out. In last week’s class here we disassembled an engine that had a failure occurring and also had no filter element.
Sounds like you got hosed.. It happens everyday with these cars, and we get the phone calls.
UOA tests for debris thats very small, less than 40 micron. Most analysis will not even detect debris larger than 40 micron.
Happy to help, but I won’t be on the forums this week, as I will be at Amelia Island supporting one of my engines that I built for the Revs Institute. I won’t be on the forums much at all, if any through spring. Taking lots of time off starting very soon. Submit a support ticket at www.flat6innovations.com and my team will help you.
Old 03-04-2019 | 09:54 PM
kearnage's Avatar
kearnage
8th Gear
Well I dropped the sump plate tonight and the situation is seemingly getting much worse. I don't have a lot of hope at this point for this engine. As shown in the photos below, there are metallic bits everywhere, including many large chunks. I grabbed the biggest chunk I could find and cleaned it up to see what color it is. It has a copper or brass color and the chip is huge! If it came from a bearing, I can only imagine there can't be much left of it. I'm guessing it's time to pronounce this one dead and send it in for a rebuild unless one of you can convince me there is still hope... not sure if there will every be hope in this one but if someone could comfort me for my loss that would be great too.
Old 03-04-2019 | 10:02 PM
Ahsai's Avatar
Ahsai
Ouch! Sorry to see that. I agree with Jake that you got hosed
Are those pieces ferrous?
Old 03-04-2019 | 10:03 PM
Mbren1979's Avatar
Mbren1979
Sad to see this crap happen. If i were you it would take everything i had not to go punch the PO.
only thing i can say is do TON's of research when it comes to a rebuild. Once you have looked at every option, send it to flat 6.
Old 03-04-2019 | 10:05 PM
Flat6 Innovations
Former Vendor
I see at least 3 significant wear metals in those pics. Please don’t start it again.
Time to issue another Death Certificate. That makes 3 for the day.
Old 03-04-2019 | 10:07 PM
SoCal911t's Avatar
SoCal911t
Well that sucks! Did you purchase from a dealer or a private party?
Old 03-04-2019 | 10:15 PM
Coopduc's Avatar
Coopduc
Yup. Time for a full rebuild, I’ve seen worse that has been resurrected to see the road again. Biggest unknown at this point is the condition of the crankshaft. As far as I know, there is no regrind possible of either the mains or crank journals.
the upside is: if you take the experts advice and follow it through to completion, you could end up with an increased displacement, high horsepower, very reliable engine. If you have the wallet for it.
if the thought of putting 5 figure sums into a rebuild makes you weak in the knees, sell it as a roller and move on to look for another car.
Better days are ahead.
Old 03-04-2019 | 10:25 PM
kearnage's Avatar
kearnage
8th Gear
Thanks for the reply, Jake. I definitely won't be starting it after I saw what I just saw. Would there have been a way to detect this without draining the oil? Would a PPI have even found this?
As for the PO, I don't know what to think yet. I bought it privately and he only owned the car for barely over a year and I don't know if he was smart enough to pull something like this off. He clearly didn't know much about cars and I answered a few of his questions about this car. Maybe he was playing dumb but if he was, he was pretty convincing. I would guess that he bought it that way and drove it until it needed maintenance. There were other problems like brakes, janky door handle, and the brake wear sensor/wheel speed sensor harness was broken on the left front which threw 3 dash lights. At least that was a straight forward diagnosis and fix for me.
Old 03-04-2019 | 10:30 PM
Coopduc's Avatar
Coopduc
A good PPI would definitely caught this, inspecting the oil filter and dropping the sump are fairly standard procedures by Porsche specialists.
i know Jake’s includes much, much more than most.
Old 03-04-2019 | 11:59 PM
lowpue's Avatar
lowpue
Wow...sorry about this....sounds like a bunch of shady characters are in the history of this car.
Jake, thanks for letting us know about the filter trick...that is yet another thing to check during ppi for sure.
Old 03-05-2019 | 12:37 AM
Flat6 Innovations
Former Vendor
This sucks... Its happening all the time.
You simply have to do a PPI, and that PPI has to be semi- invasive. A proper PPI would have done exactly what the purchaser did, then the purchaser would not have purchased the vehicle..
People get too damn anxious, and they end up being in a hurry to get ripped off.
Old 03-05-2019 | 12:47 AM
Porschetech3's Avatar
Porschetech3
Ouch !! Sorry for your loss,.. just how big an ole' boy is this guy?
Old 03-05-2019 | 01:02 AM
bgoetz's Avatar
bgoetz
Therd is no way he was driving around and didn’t realize he had problems. Way too much to make the lack of a filter coincidence, even the worst oil change place would know it needs a filter put in the housing. I personally would try to pursue this legally.
Old 03-05-2019 | 01:09 AM
jkfuel's Avatar
jkfuel
Sorry to see!
Old 03-05-2019 | 01:16 AM
808Bill's Avatar
808Bill
Very sorry!
Seller played you...
Quick Reply: Metallic Chunks in Oil
