MAF value = Horsepower potential
#136
Well, I have found that the default map reacts slowly compared to the actual MAF sensor. Sudden changes in air flow are not picked up by the default map, or at least not displayed quickly, it is Alfa-N map and uses TP,RPM,IAT to calculate/display mass air instead of directly measuring it. I have found that actual MAF can deviate quite a bit without setting a code, so use it with a grain of salt.
#137
Just want to share some cool Excel plots you can do from Durametric log for my 3.8. This one is the measured air flow (kg/hr) vs rpm plot.
From the vehicle speed measurements (6 samples per second), assume a weight of the car you can compute the rwhp and torque (measurements were done on almost flat roads).
If you look at the upper envelope traced out by the dots, you'll see that these are pretty close to the IPD plenum dyno plot.
Ahsai, what were your temps during the above maps? Can you calculate your VE at 4100 rpm? I have done it and see some serious VE, see what you come up with.
#138
I'll give it a try with the PIWIS when I can - was being held back because my laptop battery has degraded but a new one just got delivered so I should be good to go!
#139
#140
If you could do both, that would be great !! Am mainly interested in accuracy, but you are elite in that you have PIWIS, not many people has that. The different bluetooth devices, apps, phones may have problems with sample rate, or spikes, but the data comes from the DME, so the data should be the same, but slow a sample rate will cause it miss the max maf, and a spike will, well be a spike. You can recognize a spike by running a log, the spike will be out of place, slow sample rate can be countered by doing pulls in 3rd gear so that max maf will be available for a longer period of time.
#141
Hi Dan,
To do logging with Durametric, it's a bit more involved. I'll summarize the steps here:
- Go to DME Actual values
- Check the parameters you want to log (best to limit it to less than 10 or so)
- There's a small tab right above the list of parameter that says logging option or something like that
- Pick "Fast" and "Digital only"
- Save the config file, which remembers which parameters you picked so next time you only need to open this configure file as opposed to manually checking all those parameters again
- Click "Start" to start logging
- When you're done logging, click "Export" and save the log to a csv file
- Click "Stop"
Next time you log, just click recall the same config file and then click "start" to start logging.
- Click "Stop"
#142
Ahsai's instructions are great for us using Durametric, but you are using PIWIS and honestly I can't remember (Alzheimers?) the steps. Hopefully you can figure it out, or maybe it will come back to me.
#143
Thanks Ahsai and Porschetech3, steps for PIWIS are:
DME > Actual Values Input Signals > Measurements > Select Values > Data Logger (start)
Seems to be able to map to 1/10th of a second:
I love PIWIS... haha
#144
Captain Obvious
Super User
Super User
Yes and it's better for everyone else that lives outside of the US.
#145
I love these maps !! You can see a couple of "kicks" in there from the ram air tuning at about 4100 and 6100.
#146
Looks like the VE is about 110% from 4k-6k then falls to 95% from 6k-7k.
#147
Yes. The VE could be lower across the board because this is a 3.8L with 3.6 stock intake above the head gasket.
Will be interesting to see the same plots for the stock 3.6. Hopefully sometime next week.
#148
Glad to help out my neighboring countrymen. Here is a handy link to phone app for you and others when we "Mericans" use things like miles, gallons, lbs, oz, dollar, acre, PSI, Fahrenheit ect.
https://play.google.com/store/apps/d...d=kr.sira.unit
#149
#150
