996 Forum 1999-2005
What did you do to your 996 today?
Old 01-28-2024, 07:14 PM
  #9721
Willys 47
Willys 47's Avatar
Originally Posted by hbdunn
That last pic of *****'s is the right rear, so it is correct. C4S have C2 front brakes in the rear.
whew, made me look!
Old 01-28-2024, 07:20 PM
  #9722
ENV
ENV's Avatar
Originally Posted by marosmith
325xi, this is an 06’.
I love the car, super practical. Crazy rare with the manual. Low maintenance in that configuration. If I keep it someday I wanna do the 3 stage intake swap and make it a 330
have wanted one to take the place of my 03 a6 Avant. Mostly cause I want a manual wagon again as a daily.
Old 01-28-2024, 09:47 PM
  #9723
fazm
fazm's Avatar
^^ the e91 won't let you down
Here's me: finally got my 996 gauge cluster wired up and bolted in. Everything appears to work, even had the mileage moved over. I'll probably need a local shop with PIWIS to code out whatever errors the confused cluster has. Maybe I can clear it with Durametric. We'll see! For now, I'm just glad to see my 986 showing signs of life. Gotta do the under drive pulley, button up the interior, and get back on the road!
TexSquirrel (01-31-2024)
Old 01-28-2024, 10:41 PM
  #9724
De Jeeper
De Jeeper's Avatar
Received 3,439 Likes on 1,804 Posts
Just for the record thats not 100% true. The calipers r the same-ish but the pistons r smaller.
Old 01-28-2024, 11:08 PM
  #9725
fazm
fazm's Avatar
Is there any chance someone has a link handy for the Onboard Computer user guide/manual? I'm setting up my control switches, but don't know how the menus work and I'd like the button layout to reflect how it works!
NVM: When someone invents time travel I intend to speak to some porsche nerds/engineers...
Ratchet1025 (02-01-2024)
Old 01-28-2024, 11:32 PM
  #9726
hbdunn
hbdunn's Avatar
Oh did not know that. Knew the pads were the same.
Old 01-29-2024, 12:17 AM
  #9727
theJRUHL
theJRUHL's Avatar
DIY string alignment before the 30mi drive for alignment and corner balancing
The following 11 users liked this post by theJRUHL:
bmchan (01-29-2024), Boss_Angeles (02-23-2024), circuit.heart (01-29-2024), EVOMMM (01-29-2024), fazm (01-29-2024), Geoff.T (01-31-2024), gtxracer (01-31-2024), imhighlander (02-03-2024), Ratchet1025 (02-01-2024), TheChunkNorris (01-29-2024), wdb (01-29-2024) and 6 others liked this post. (Show less...)
Old 01-29-2024, 12:24 AM
  #9728
De Jeeper
De Jeeper's Avatar
Yea the pads r the same. The rear calipers share the part number with the gt3 and turbo rears. They have the same important dimentions as the front c2 calipers but they have an extra mounting boss that is tapped to accept a bolt to secure the short hard line. The front c2 caliper hard line bolts 2 the upright.
gt3 rear pistons r 28 and 30mm.
c2 front pistons r 36 and 40mm.
I use the c2 fronts in the rear because the 6-gt3 pistons r large and i needed more rear bias. They reduced the piston size in the 7-gt3 to help equalize the car. My car now has the same percentage of bias as the 7-gt3 but larger pistons so the brakes have a very good responce.
Thats the end of rhe non solocited brake info for today.
The following 3 users liked this post by De Jeeper:
EVOMMM (01-29-2024), Ratchet1025 (02-01-2024), wdb (01-29-2024)
Old 01-30-2024, 08:45 PM
  #9729
Pencap914
Pencap914's Avatar
Default Front suspension refresh.
New front B4 Shocks, mounts, control arms, inner/outer tie-rods and drop links. Only hiccup was the dust boots supplied by FCP Euro were the wrong size. I have the earlier smaller steering rack that needed smaller boots. Anyone need a set of dust boots can have mine for price of shipping. Got the car aligned and boy what a difference. Now wishing I did the rear at the same time. But I knew I only had enough time to do half the car, so I went with the front since it was staring to get noticeably bad.
The following 4 users liked this post by Pencap914:
Boss_Angeles (02-23-2024), gtxracer (01-31-2024), wdb (01-30-2024), Woodman71 (02-01-2024)
Old 01-31-2024, 05:00 PM
  #9730
RTSC4S
RTSC4S's Avatar
…install of the OEM SUB TRAY it’s called. Really always like the interior with full leather in this “peanut butter”…natural brown. Waiting on nameplate “Bose” surrounds brackets. The subs are not Bose …farthest thing from it so will come up with @ logo switch later…more to come…word of note. Bose system OEM set up to see 2ohms in parallel…most OEM use this set up to get most out of cheap speakers. Be cognizant of your coils being dual or single …I set up at 1ohm and it kept cutting out the amp. Went to 4ohms…problem solved.
What spectators see…the way Ferry wanted👏🏾
“There is no substitute…”. Wow…I always wanted to say that
The following 2 users liked this post by RTSC4S:
gtxracer (01-31-2024), peterp (01-31-2024)
Old 01-31-2024, 05:12 PM
  #9731
gtxracer
gtxracer's Avatar
Originally Posted by theJRUHL
yes sir…geline GA3R Wheels- 18x9.5 +46 & 18x12 +46
nee to dial out some camber in th rear and add a little in the fron
Love the feet kicked up in the 2nd photo...what tire sizes are you running front and rear? The sidewall thickness looks *chef's kiss*
Tweaked alignment and installed new cross members in the rear and front today in preparation for the real alignment and corner balancing… thought this was a cool photo of all the new suspension, wheels, tires, etc
Same question for you...what's your tire and wheel specs? I have a set of 18x12 Fikse FM10s going into the rear of my C2 and still comparing specs. Thanks!
Old 01-31-2024, 05:15 PM
  #9732
gtxracer
gtxracer's Avatar
Did your car come with the sub tray or did you purchase separately? I think I like this setup more than mine, even though I poured dozens of hours into my box and mounts.
edit: saw your post here - great design! maybe I'll redo mine at some point.
Old 01-31-2024, 05:20 PM
  #9733
996C438
996C438's Avatar
I installed a 2 quart oil sump extension . I bought this from Jake Raby , he had done some internal mods/upgrades to the baffles/doors . Anyway all went as expected following the LN instructions . I will wait 2 days before adding oil to let sealant setup . Hopefully no leaks 😋 . Next I will purchase the LN skid plate and install .
While I don't race I am a firm believer in oil volume . I want my 3.8 to live as long as possible . I have the same setup on my 3.6 Boxster since 2015 . I will be able to run 11 quarts thanks to the UAOS .
The following 4 users liked this post by 996C438:
EVOMMM (01-31-2024), Porschetech3 (01-31-2024), Ratchet1025 (02-01-2024), TexSquirrel (01-31-2024)
Old 01-31-2024, 05:57 PM
  #9734
TexSquirrel
TexSquirrel's Avatar
Received 2,423 Likes on 1,288 Posts
It's nice to know you have an extra 2 quarts when the oil level starts flashing.
Meh, I'll add half a quart soon when the weather is nice.
Old 01-31-2024, 06:23 PM
  #9735
DBJoe996
DBJoe996's Avatar
Received 1,181 Likes on 756 Posts
Caught my 996 mileage today
And ready for an oil change with new SS LN magnetic sump plug and copper washer. I'm excited!
The following 2 users liked this post by DBJoe996:
Boss_Angeles (02-23-2024), Ratchet1025 (02-01-2024)
Quick Reply: What did you do to your 996 today?
