996 Forum 1999-2005
What did you do to your 996 today?
Old 06-21-2019, 02:34 PM
  #1576
dporto
dporto's Avatar
Received 1,165 Likes on 795 Posts
Originally Posted by wildbilly32
Love this...come on Sept 30th!
Sept 30th? Wow! That'll be a quick one - you must have gotten a "lucky slot"... In any case, whenever you get it back you're gonna luv it! Which build did you opt for again?
Old 06-21-2019, 02:39 PM
  #1577
Mike Mullins
Mike Mullins's Avatar
Default They do look good.
What the Color code on your T(S) ?
Originally Posted by Capt. Obvious
I test fit my new wheels the other day.
Old 06-21-2019, 03:34 PM
  #1578
Capt. Obvious
Capt. Obvious's Avatar
Received 1,469 Likes on 809 Posts
Lapis Blue Metallic (3A8)
Old 06-22-2019, 12:44 AM
  #1579
Ratchet1025
Ratchet1025's Avatar
secondary ? New MPSC2's ? What were you impressions , Mine seem to take a lap or 2 to generate heat, but once they are, they stay consistent until done lapping. Not great for autoX but DE's etc. they are tough to beat actual treadwear usage.
I got 2-3 more DE days than Hooisers, Toyo's, which seem to get greasy 12-15 laps into session..
I have a Micheln guide for Tire pressures and Suspensions settings somewhere. I'll see if I can find it.
Regarding the Sport Cup 2s, very happy. My only other track tire was the Hankook RS4 which I also thought was great. RS4 had good wear, mostly predictable, just not enough grip at the max (mainly due to tire sizes). The 235/295 stagger of the Sport Cup 2s is really fantastic, very balanced. I am still getting used to the lower pressures (must be under 35 hot, 31~32 is the target).
Sooner or later, want to try the 245/305 or 315 stagger that others are running, just haven’t done the research yet.
Please let me know your tire size/pressure experiences!
Old 06-22-2019, 09:20 PM
  #1580
wyovino
wyovino's Avatar
Originally Posted by dporto
This airbox has been kicking around my house for a couple months while waiting for my car to come home with its new FSI/Raby power plant...I couldn’t remember where it was for a few days, then remembered that I had moved it to the shed...When I finished bleeding my brakes on Tuesday night I popped it in there... Looks so much better than the stock 3.4 airbox 😃
Did you have to reposition the secondary air pump?
Old 06-22-2019, 09:28 PM
  #1581
Mikelly
Mikelly's Avatar
I spent the morning swapping out the HVAC compressr hub/bearing//Pulley/ magnet/clutch. I now have a vibrating line in the passenger front fender well I’m trying to quiet down. Always something.
Old 06-23-2019, 12:32 AM
  #1582
ThatSalesGuy
ThatSalesGuy's Avatar
Sold mine
Old 06-23-2019, 02:26 PM
  #1583
DGI
DGI's Avatar
996.2 radio surround upgrade began last night. Need to do some trimming so will see how it goes tonight.
Old 06-23-2019, 06:54 PM
  #1584
dporto
dporto's Avatar
^^ No - I didn’t even try it with the included snorkel... I just swapped the stock snorkel from the 3.4 airbox. Fits perfect no problems, no repositioning the sai
Old 06-23-2019, 07:40 PM
  #1585
cds72911
cds72911's Avatar
I'm late to this, but I used a 997 3.6 airbox with 996.2 snorkel with no problems.
Old 06-23-2019, 07:50 PM
  #1586
996AE
996AE's Avatar
Received 1,455 Likes on 959 Posts
Post IMSS install started it on the lift and looked and listened to my very expensive non performance mod on my beautiful 996 AE. Replaced RMS and AOS so watched for leaks.
Glad to report dry as a bone after a month in the desert.
Old 06-24-2019, 08:23 AM
  #1587
DGI
DGI's Avatar
Im assuming AOS is alot easier to get to if youre in there to do the IMS/Clutch/RMS? Collecting parts for my IMS job and figured i'd add the AOS to the list if it makes sense.
Old 06-24-2019, 09:16 AM
  #1588
DBJoe996
DBJoe996's Avatar
Received 1,158 Likes on 742 Posts
Ordered a set of these from Suncoast https://www.suncoastparts.com/product/SKU9X6RUBBER.html
Old 06-24-2019, 03:37 PM
  #1589
Ratchet1025
Very nice, thanks for the link.
Old 06-24-2019, 04:16 PM
  #1590
sasilverbullet
sasilverbullet's Avatar
Originally Posted by ThatSalesGuy
Sold mine
Funeral derge playing...
Are you getting another one?
Quick Reply: What did you do to your 996 today?
