Rear window regulator on cabrio
Has anyone had their rear window regulator on a cabrio break?
I just placed the hard top on my car and when putting up one of the rear windows heard the dreaded crunch.
Porsche parts sell for over $800 but I found this rebuilder on Ebay that will do it for less than $200:
https://www.ebay.com/itm/99-05-Porsc...haHJTc&vxp=mtr
Does anyone have experience with them or any other place where I can either buy a new part or get mine rebuilt?
Thanks!
Thanks!
Thanks!
Thanks!
It’s not the easiest job to remove the rear regulator on a Cab. On the other hand, now that I’ve done it once, I could easily and quickly do it again.
What recommendations do you have for removal? I haven't found any documentation for it yet. I've done then main windows before and it wasn't too difficult but imagine there's less room in these smaller spaces so might take more effort.
Guess I'm not using the car for a while now.
How did you finally fix yours?
I thought this one would be easier but I guess I have my work cut out for me.
The module on mine - the electronics - cannot be easily found or purchased separately. So I paid for a motor assembly that came with the module and gears (which I still have), and I swapped only the module and everything works fine.
I ended up spending nearly $380 in all, but could have easily spend 2-4x that cost with a new one installed by someone else.
Just give me a call if you want - PM me - and I’ll walk you through a couple of tips and tricks. For example, I removed all of the bolts from the convertible top assembly, and I had to wedge a gap to make room to pull out the regulator assembly. It was easiest to have the window in the down position.
The entire regulator assembly has the following components: motor, module, gears, carrier, cables, pads. The module on mine was bad, but they still rebuilt the motor and cables because they wanted to make sure those components would last another 50,000 miles, etc.
I'll take it apart tonight and see what lies ahead for me and reach out to you after I see what I'm up against. Thanks again!
Ok I need some help. I removed every bolt I can see except for those that hold the hydraulic assembly for the convertible top as I wasn't sure if those should be touched or not.
The problem is I have no idea where to go next. I can only pull the window about halfway up as it appears the regulator is pretty much destroyed so it won't go up any further. I have the convertible top about halfway up so not sure if this ideal but that's what I've read is a best practice.
What should I do now to remove this thing? I know I've seen mention of a bottom nut, not even sure where that thing is as I do have the rubber grommet underneath but not sure if I even have this positioned properly to get to it.
Thanks!
Thanks!
Rubber grommet also doubles as the hole that allows access to the Bolt than holds the window regulator
I can see the rubber grommet is still plugged in at the very bottom. It has wires coming out of it. You can pull it out, being careful not to destroy any wires. With the grommet out, you can actually see the nut and you will need to likely use a 6” extension to get to it, or a long Allen.
Definitely check out the links on the other thread. There are diagram on those links and instructions that are helpful.
The pic I’m attaching shows the grommet
Does the window have to be all the way up or can it be in this halfway position? Is it best to pull it back down?
Thank you so much for helping along the way!
It's out! Here's the big ugly beast that was quite difficult to wrestle from its resting place.
I'm not sure what is worse, working in a 100 degree garage in the summer or a 20 degree garage in the winter. Of course I never have these issues during milder temperatures.
In any case I have several nuts, bolts, and even a block of wood now sitting in my fender that I have to retrieve but at least I'm glad this thing is out. Now the challenge will be putting it all back together again and hoping it and my convertible top work again!
For those who are wondering I'm going to send it off to get rebuilt with the link I initially posted from eBay. It's outrageous that Porsche charges $800+ for these things new - there is nothing special to it except for it being so difficult to get to.
Awesome, I’m glad you got it out. It’s not that easy to get out; it took me like 2 hours to figure it out. I hope the rebuild goes well. I agree, $700-$800 for the part is unbelievable. It just must be a rare part - coupes don’t have them, and other 911 variants probably have different Parts is my guess.
