Chewed Up Bolt Found in Oil Pan
Camshaft sprocket bolt looks to be 12 mm, but OP said its hard to measure: http://www.sierramadrecollection.com...08-p28525.html
It can't be a plastic bolt, he found it because it stuck to his magnetic oil plug.
I am new to these cars, so probably wrong, but this looks exactly like IMS flange bolt to me (h6 x 20MM). http://www.sierramadrecollection.com...01-p22413.html
I would also imagine that if this thing fell out of the head and made it's way into the pan, you'd have a lot more trouble than just a zero oil pressure reading, no? Is it possible that the person that did the IMS dropped this, and its been in the pan the whole time and at various points, it runs into something that chews it up? Seems incredible to me.
Also, all debry was found inside the baffled area of sump cover. There were no other contaminants outside of baffle area. Not sure this means anything but the Bolt and other materials were to big to flow in from outside of baffle. The aluminum piece was sucked up to screen on pickup in sump. Could these things have partlally reduced the oil pressure and then when I pulled over the idle pressure dropped the pieces resulting in normal pressure again?
Thanks for responses and I will continue to update and inspect anything that someone thinks should be looked at.
No way for an IMS flange bolt to get into the sump...
Couple of thoughts. Are all the bolts that retain the baffles to the sump plate in place? Did you have the AOS replaced - thinking someone dropped a bolt into the hole during the replacement process?
Not the METAL bolts for the black plastic chain rail - too long per PET. Weird thing is I think the sprocket bolts are hex heads.
Bolt looks like case bolts or bolts for the suction tube or the swirl pots, but doesn't look like anything is missing from the pics.
I don't recall any other similar bolts that would make it to the sump. But regardless of where it came from, and considering the bolt could have been "left in there," the bolt is pretty mangled. If mangled by the engine, then I'd be worried something else is damaged and unfortunately, the only way to figure this out is to split the case.
Expensive now, probably much more expensive later.
A few things interesting in your sump photos. The bolt on the oil scrapper should be an internal hex but yours is a torx. Similar for the other bolts on the sump swirl pots.
Hard to tell how long the broken bolt is. The ones on the cam sprocket are 12mm long. The other possibilities I can think of are case bolts and cam cover bolts (both quite long though).
Looks similar to this one from this guys 997.1 sump thread where he didn't know about male torx.
https://rennlist.com/forums/997-foru...n-on-sump.html
Received 1,122 Likes
Hmmm...could be a manifold bolt dropped in there during AOS replacement, or an oil filler pipe bolt that got dropped in there. Here is what I would do, make sure every damn bolt is accounted for inside the engine sump, and re-torqued to spec. Now for the weird part. I would button up the sump, re-fill with oil and run it. I have no idea how it got in there and don't want to speculate how it got banged up. The oil pickup filter screen prevented it from getting anywhere inside the engine. It is not a rod bolt so you don't have to worry about that. If it dropped into the sump from one of the cam sprockets, then it would take a lot of dismantling/checking to get to those. If you have had no other ticking, banging, thumping or other weird noises, let's just say you found it, removed it and move on. Run a Durametric scan on cam angles. Run oil analysis and watch/listen for anything not normal. Looking at $20-24K for a rebuild is absurd at this point unless you have time/money to burn. You could tear it all apart and do a forensic analysis, or it could be a big waste or time/money. Just my 2 cents.....sometimes life is a mystery.
This is what I was thinking too, if someone was clutzy and dropped it when doing an AOS swap?
So if the oil analysis comes back positive, my oil pressure stays stable after installing new sensor and I do not hear anything not normal, I will drive, check oil frequently and start saving for the future.
Is there any reason not to do this? Spend $10-15k now not knowing or $15-20K later if it blows?
This question was brought up a couple of times and I wanted to respond, I have not (nor do any of my receipts) show that the AOS has been replaced. I perform a crank case pressure check each time I do an oil change and my pressure is at 4.81 in wc.
Thanks so much for everyone's comments and help, This question has also been brought up a couple of times, my engine appears to be original, see pic below. I asked my Indy about this and he mentioned that Porsche switched from the hex head bolts to male torque in mid to late 2004.
If you go with the "rock what you got" plan, I would recommend a 2nd oil analysis and filter check at 500 miles. You don't have to do a full oil change and it should provide additional peace of mind or confirm things are going downhill.
