Dension Gateway 500 - CDC Enabling with PIWIS
#46
The biggest road-block to using PIWIS is FEAR.
Don't be afraid to explore options, you can't DO anything, that can't be undone.( if you document what you've done)
Rules
1. Remember/log/wright down every step you take ( go back to main menu/start frequently until you are comfortable )
2. Make only one "change" at a time ( so you can reverse/remember it if undesirable change)
3. Looking at data or info or options, makes no changes
4. It should be clear when you're about to make a "change", and if in doubt always ask yourself," am I looking at data/info/options, or am I fixing to make a "change'.
5. You will never learn or get used to PIWIS if you don't explore/play/investigate with it. It has a VAST amount of info/ functions/abilities.
Rules
