Happy "New To Me" 993 Twin Turbo
I was told that if you program out the immobilizer, you would negate the "roll over feature" which shuts fuel off in a rollover/accident. I don't know if that is true, but I kept the immobilizer when the computer was reprogrammed.
I had the oil, brake and transmission fluids changed today. Recharging the AC in a couple days. All belts look good. Only 5,000 miles on the clutch and plugs.
She vibrates at 50 mph and then significantly more when braking. I though it was a warped or rusted rotor. It turns out the bushings are dried out and cracked. That should be resolved later this week or next. Any suggestions on bushings?
I need to replace the tires. OEM Bridgestones are on the car, I've always been a Michelin guy, but Hanooks are very well priced. I need the bushings done first so that I can have the alignment done at te time of new tires. Any suggestions on tires?
I hand washed the car tonight and used Adam's Brillant Glaze. Wow it looks great and Brilliant Glaze is easy and deep. It's very temporary until I get a chance to clay bar and polish out the swirls and use GTechniq EXO. GTechniq EXO is terrific.
Walrod Bushings - if it the front A-arms. Do a search.
Best valued tires - Sumi's III's - seem to be better than the Hankooks, I like them.
Cheers,
Mike
Cheers,
Mike
I have never installed nor driven a car with Elephant bushings, so I cannot compare directly. All I can say is no issue and positive results for the Walrod's.
Cheers,
Mike
