Stiff clutch
Hi guys.
The clutch is a lot stiffer than normal before I start the car. When the car is started it appears to be normal and there is no slippage. After I turn the car off, it becomes stiffer each time I pump it.
Any ideas?
Any ideas?
that sounds like an accumulator, but from what i've read, if one fails, the other isn't far behind.
Accumulator is cheap at approx. $105
slave is about $600 plus labor
..is one of TT's congenity problems. I changed both (accumulator and cilynder slave) almost four years ago. If one or other is fault, You must find some oil leak inside the front lid
Ciao Nicola
P.S.: You can use the car without any problems until change this stuffs.
Ciao Nicola
Problem seems to have gone away today. I'm scratching my head on this one. Think I'll wait to see if it reappears.
Thanks for your help everyone.
Slow leak in the accumulator, probably bleeds down over a period of time. Works fine when car has run recently, not so good when it sits for awhile. Don't hold your breath on any problem "healing".
Well, looks like I may have the same problem and didn't even know it was a problem until I read this post. The clutch is very hard to push until I start the car. I just figured it was stiff until the hydraulic assist kicked in when you start it. Thanks for the insight. I'm new to Porsche's so did not know any better. Is there a problem driving it like this until I can get it fixed (which may be a few months since we're in the process of a move)
