Highest clamping force OEM pressure plate?
Any of you guys know which OEM Porsche Pressure Plate has the greatest clamping force? It can be a Motorsport item as long as it has a Porsche part number on it. It cannot be a multiplate clutch. Single plate only. I know sachs makes some but I have to have something with a Porsche part number. It is a long story I won't bore you with.
Sprbxr
I think you will find most of what you need here:
https://rennlist.com/forums/5555559-post31.html
You will find much more info also if you do a search on this board.
Sprbxr
Thanks for being the thread police.
If you could share them with me that would be great. I am owed some parts and the entity that owes me the parts can only send me Porsche OEM part numbers.
I am looking for the highest clamping force, Porsche OEM, clutch package. It has to be available from the Porsche parts distribution network. IE: the dealer.
Thanks for your help.
Justin
Justin
Justin
Any of the below references are the same, and the same used on the 997GT2 as well:
• 964.116.027.00
• 964.116.027.01
• 964.116.027.02
• 964.116.027.03
• 964.116.027.51
• 964.116.027.52
• 964.116.027.90
• 964.116.028.00
• 964.116.028.02
• 964.116.028.03
• 964.116.028.50
• 964.116.028.52
• 964.116.028.53
• 964.116.028.90
• 964.116.028.91
• 964.116.911.00
• 968.116.911.00
• 996.116.020.51
• 996.116.027.51
• 996.116.027.90
These are equivalent to the 752 pressure plate and the highest clamping force you can find with Porsche part number. There is a Sachs pressure plate (764) that is stronger but no Porsche part.
• 964.116.027.00
• 964.116.027.01
• 964.116.027.02
• 964.116.027.03
• 964.116.027.51
• 964.116.027.52
• 964.116.027.90
• 964.116.028.00
• 964.116.028.02
• 964.116.028.03
• 964.116.028.50
• 964.116.028.52
• 964.116.028.53
• 964.116.028.90
• 964.116.028.91
• 964.116.911.00
• 968.116.911.00
• 996.116.020.51
• 996.116.027.51
• 996.116.027.90
And this is for the puck type racing clutch:
950.116.013.00
964.116.013.00
964.116.013.01
964.116.013.50
964.116.013.51
964.116.013.52
964.116.013.61
964.116.013.62
964.116.013.90
964.116.014.00
964.116.014.51
964.116.014.52
964.116.014.62
964.116.014.90
964.116.014.91
964.116.911.00
Some or many of these references will not be available anymore, but I "think" any of them works and are the same part in essence..
The above combo of clutch and PP that I just listed takes you to 640lbs. ft of torque, beyond anything that you could run on the track.
950.116.013.00
964.116.013.00
964.116.013.01
964.116.013.50
964.116.013.51
964.116.013.52
964.116.013.61
964.116.013.62
964.116.013.90
964.116.014.00
964.116.014.51
964.116.014.52
964.116.014.62
964.116.014.90
964.116.014.91
964.116.911.00
764, 96411601301, 96411602790, 96411602803, 96411691100, 993, 99611602051, 99611602751, clutch, makes, number, oem, part, plate, porsche, pp, pressure, sachs
