993 Forum 1995-1998
Help finding 993 key LED conversion DIY?
Old Mar 8, 2016 | 06:08 PM
RudyP's Avatar
RudyP
Default Help finding 993 key LED conversion DIY?
A few years back I found a DIY guide that explained how to replace the small incandescent bulb in the standard 993 key (2 part key/remote, not switchblade) with a modern LED, two small watch batteries and how to reassemble the whole unit so that you would get much better keyhole illumination from the key. I did the mod and it was great until the wires broke off inside from use and it no longer works. I want to do it again but can't find that DIY guide.
I believe if was on here but I have searched here (as well as pelican forums and straight google) and can't find anything. Anyone know about this DIY article and where I could find it?
Old Mar 8, 2016 | 06:26 PM
uniquenamehere's Avatar
uniquenamehere
https://rennlist.com/forums/diy-subm...d-diy-mod.html
This one?
Old Mar 8, 2016 | 07:34 PM
BobbyT's Avatar
BobbyT
There is another DIY here, just scroll down to "L.E.D. Key Light conversion" after the link opens:
http://www.pcarworkshop.com/index.ph...chblade_remote
Old Mar 8, 2016 | 10:06 PM
RudyP's Avatar
RudyP
Thank you both - that is perfect!!
Old Mar 8, 2016 | 10:43 PM
P-daddy's Avatar
P-daddy
Deleted
Old Dec 31, 2018 | 09:45 PM
Alfa40's Avatar
Alfa40
I did this conversion and had a functioning key light for a couple of weeks before the LED died. Aren't LEDs supposed to use a resistor when drawing from 3V of power? Maybe someone more knowledgeable can help out? Where does everyone order their LEDs from? I bought this one, by the way.
Old Dec 31, 2018 | 11:08 PM
RudyP's Avatar
RudyP
This may not be the answer you are looking for but since starting this thread in 2016, I found out if you order a new key head from Pelican Parts (or probably other places) for $30 or so, it actually comes with an LED light now. So if you really want to do this cheap and DIY that may not help but otherwise, for $30 you can get an improved replacement.
https://www.pelicanparts.com/More_Info/94453804101.htm?pn=944-538-041-01-M100&gclid=Cj0KCQiAmafhBRDUARIsACOKERNxiLFFJRLY4mTtyIhvAiqnfUTqs1-MU1kYCfLFo-WSlQ8rF0GD1HEaAkC5EALw_wcB
By the way, it's still a bit finicky to actually light when you press the button, just like the old one.
Old Jan 1, 2019 | 05:09 AM
Alfa40's Avatar
Alfa40
https://www.pelicanparts.com/More_In...EaAkC5EALw_wcB
Thanks for that, but my key has a silver logo that I really like, would love to keep using that one...
Old Jan 1, 2019 | 11:53 AM
HalfGerman's Avatar
HalfGerman
You could always swap to new key head.....
https://www.pelicanparts.com/More_In...8aAjS1EALw_wcB
