portable automatic stop compressor?
Haven't been lurking in a while, Hi to all, just been busy.
Anybody know of an electric portable air compressor I can take around at each corner and set an automatic stop at a chosen psi? I want to bend down once and gitterdone in one step. Enjoy more, tweak less.
Jaime
Jaime
Hi Steve!
Costco has such a device, although industrial. They hook the key onto the tire valve, input a pressure into the gismo and it either inflates or deflates depending on your desired pressure on that tire. Presto, done. This is what I'd like. You'd think somebody would have applied this to the home. Sounds easy enough right?
Yeah, I got the expensive large gauge etc., Too many steps, getting old
This is about as close as you can get for the money. Hook it up to a compressor or an air tank.
http://www.griotsgarage.com/product/...Picks&refType=
RL Technical Advisor
FWIW,......
Several years ago, I sent my entire collection of tire pressure gauges to a testing lab for calibration since I'd seen wide discrepancies on the same tire and didn't know which one(s) were telling me the truth.
The big epiphany was that only one of the six was accurate in the pressure range that I used most; the rest were more than 5 lbs wide of the target and that was/is unacceptable to me.
The only one I use now is my digital Longacre one; the rest are cool ornaments.
Which model Longacre do you recommend for the amateur?
Thanks,
Michael
Thanks,
Michael
FWIW,......
This is the one that I use. It is quite handy:
Craftsman C3 portable inflator
