Coilovers... KW V1 vs. H&R Street Perf.
Hi,
I appreciate all the suspension help that you guys gave me in my intro thread. I was going to order the B6/H&R combo from Carnewal but he is out of stock and i'd only see them in a month or more, so I decided to go for the V1 or H&R coilovers instead.
I'm not sure if anyone has tried both, but for the same price I think i'm leaning towards KW.
I also noticed that in the Carnewal kits he included links for the rear. Will i need to change these when i go with either of these coilover kits?
![](http://www.carnewal.com/cpx/p93106.jpg)
Car pic with 4x4 suspension:
![](https://i1112.photobucket.com/albums/k492/kaceyfourtwenty/A87F355D-E5A4-4FDF-A830-54B6A5CA6629_zpsrtnlrbhy.jpg)
Condo life.. stuffing 2 cars in one spot![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
![](https://i1112.photobucket.com/albums/k492/kaceyfourtwenty/5245BB53-1136-499E-93B2-BCB52878711B_zpsthjdcgfs.jpg)
fwiw, I have the KW V1's on my C4 and while they are fairly stiff, I love them. My version of stiff might be a totally different description than yours. I say go KW V1's.
Thanks Rich! I recognize your name from the VW scene. I think KW is the way to go as well. Your ride height is perfect, are you on RS uprights? Are the bump steer issues noticeable? Thanks.
I have KW V3's on the Turbo - nice handling shocks but have a what I think is a major flaw in their design - the rear dust covers are made of brittle plastic and they tend to catch on the side of the shock, thus shattering. To replace the cover means removing the shocks and losing your alignment.
I discussed this with KW, they said "Ooops, we had a batch of KW Shocks where we shipped with the wrong ones" - so I said OK, ship me the right ones, and what about the $300 cost for the alignment, nevermind my labour for removing/installing the rear shocks. They would not cover it, citing the legal language in their "warranty".
So the covers show up, and they are identical to the shattered ones - so I get back to them and ask WTF - and their response was basically oh you have the right ones after all, too bad, so sad, they consider what they did a "favor" and I should be happy.
At the time, I stared a thread here on Rennlist and turns out other KW owners have seen this - which when I told KW they ignored.
To add to the insult, they shipped it across the border against my instructions, and I had to cover the $40 broker fee to get two crappy plastic covers which are now sitting in a box in the shop. I am not going to install them, what's the point when the original identical pieces failed?
if I had the choice again, I would go PSS10, which was my initial inclination. I wanted to try the dual valving.. my mistake, not to be repeated again.
Cheers,
Mike
Cheers,
Mike
H&Rs here, which from what i heard are rebranded bilsteins. So far so good, car tracks very straight on highway, did fine during DE. I doubt it makes real difference as long as you are using good set with proper alignment.
H&R gets their Shocks supplied from Bilstein and they use their springs. thats the H&R kit.
I would like to ride both setups and see what i like before pulling the trigger. Also if you need I can see TireRack has the suspension you want in stock, I have a Wholesale acct.
Have you looked into Pss10? I loved my pss9's. I am using H&R progressive springs with Holstein HD and they are ok. I don't like the sound the springs make when heavily compressed.
Howard
1997 911
Howard
1997 911
Check my thread >> HERE << . Even the guys I spoke with at KW USA didnt know why they don't list the V1's as an application, lol.
My alignment shop, that also builds race cars says it's all about getting the toe settings correct.
I have the H&R complete coil-over kit, now for 4 years. I use my car for street driving. Nice and smooth, car stays flat on hot turns. Can be had for less than $2000 complete. The strut bodies allow for a very large range of height adjustment where the allowed minimum ROW height for a factory setting alignment is a much smaller range. The strut bodies and spring perch hardware are all nicely finished aluminium. The original torsion bar down links can be reused no problemo. I like the ride now, a significant upgrade from OE stock.
Thanks alot everyone. I ended up ordering the H&R coilovers on tirerack since i have a wholesale account. So hopefully i get get them installed, the car aligned and balanced and corner weighted by next weekend!!
