PPI - Everything on car was great, except..
It has an oil leak. Garage quoted around $4000 to fix...
Question, I'm getting a great deal (rock bottom) on this car. Should I demand the seller fix it 100%? I think I know the answer to that question..!
_______________________
1996 911 C2 Cab - 42k miles
Not sure, but they said it was major and we could be looking at 40 hours of labor... f this, I'm walking...
Oh and get this. The mechanic went ahead and did the compression test without calling me about the OIL LEAK...
Scott's Import Specialists in Greeley Co (where the car is..)
Trouble is, the "oil leak" could just be from someone over-filling it at last oil change or checking the level improperly, then "topping it off" with a quart or two. It happens all the time. Can you get a second opinion or are you confident with the shop doing the PPI. Anyone nearby who could stop by and do a "RENNFAX" for you?
Not sure there's anything else I can do, but walk.. and ONLY pay for the PPI, 2 hours tops. Opinions?
Mine has weeping at the chain cover, and on the passengers side valve cover...never seen a drop on garage floor with lower engine cover off. Supposed to be an easy DIY to remedy. Maybe it's just something like this...
Now here's the situation I'm in. The mechanic is going to want me to pay for a compression test for the seller to get his car. NO F'ING WAY I'm paying for anything more than 2 hours.
They should have called me after the found the leak and BEFORE they went any further on the test. Thoughts?
Really you could just walk without paying anything except the PPI charge you agreed to. It's not your car, so what can they do to you? You can fight any charges if they try to bill your credit card.
I just feel bad and don't wanna stick the seller...
