993 Forum 1995-1998
Strange Sound Rebuild Rebound Thread
Old 06-03-2013, 07:10 PM
  #61
Vorsicht
Vorsicht's Avatar
Hmm. Wonder what these are for?
Old 06-03-2013, 07:17 PM
  #62
Vorsicht
Vorsicht's Avatar
Rod-crank clearance all check out between .04mm and .05mm. Rods on crank assembly complete.
Old 06-03-2013, 07:22 PM
  #63
Vorsicht
Vorsicht's Avatar
Originally Posted by trophy
how much did they have to take off to get the bore's right?
They said they took off 5 thousandths from each side. In the return box I got 6 barrel shims to go between the case and the cylinders.
Old 06-03-2013, 07:23 PM
  #64
trophy
trophy's Avatar
Interesting, Everything is looking good there Peter.
Are you doing the rebuild inside your house or is that you Garage?
Old 06-03-2013, 07:38 PM
  #65
Vorsicht
Vorsicht's Avatar
There was an empty apartment in my building. The manager is letting me use it temporarily. I wanted a clean location to put the bottom end together. I plan on doing everything up to sealing the case and then return to the garage for final assembly.
Old 06-03-2013, 07:45 PM
  #66
e3photo
e3photo's Avatar
It is looking very good. I will be following your progress closely. I am still waiting for parts to come back.
Emerald
Old 06-03-2013, 07:47 PM
  #67
Mike J
Mike J's Avatar
Looking good! Cleanliness is key at this point for sure.
When you seal the case halves together, are you going to put some sealer/adhesive on the inside bearing ribs to try to minimize the fretting? Got be be careful, since it has to be very thin so it does not add to the clearances.
Cheers,
Mike
Old 06-03-2013, 07:58 PM
  #68
Vorsicht
Vorsicht's Avatar
Cheers,
Mike
Here is my plan:
Very thin Loctite 574 on the inside mating pieces. Three bond 1194 around the perimeter and Three bond 1211 on the number 8 saddle. Then some Curil-T on main seal gasket area and the Pulley gasket and DOW 111 on the Viton through bolt o-rings.
Old 06-03-2013, 08:29 PM
  #69
trophy
trophy's Avatar
I am going to do my rebuild in the house, all the way to P&C's just to make sure the bottom end is all sealed up and no nasties can get in.
That's a good sealing plan Peter.
Some advise against any sealant on the RMS, I am still back on forth on going dry or using Curil-T
Old 06-03-2013, 09:13 PM
  #70
ca993twin
ca993twin's Avatar
Wink
Those look like the packing material that came with the rods. You can just toss them away.
Old 06-03-2013, 09:16 PM
  #71
ca993twin
ca993twin's Avatar
I know its just an optical contusion, but I only count 5 rods.
Old 06-03-2013, 11:16 PM
  #72
killsbugsfast
killsbugsfast's Avatar
Glad to see you have kept your humor through all of this
Great job, keep at it.
Old 06-04-2013, 12:38 AM
  #73
Vorsicht
Vorsicht's Avatar
I'm using a virtual sixth rod on this rebuild. It allows the crank to spin faster. Aerodynamics.
Old 06-04-2013, 02:13 PM
  #74
Vorsicht
Vorsicht's Avatar
I need some help. On the left case there is one sole stud on the mating surface in the corner (see pic below, no. 35). In looking up the projecting length the shop manual says, "Discontinued". Do I just leave this off? Seems strange???
Old 06-04-2013, 02:21 PM
  #75
NP993
NP993's Avatar
Here is my plan:
Just out of curiosity (because I am rebuilding my engine soon), but where did this guidance come from?
Quick Reply: Strange Sound Rebuild Rebound Thread
