WTB 993: Narrow body vs wide body -- help me decide
#121
The only difference is 25mm more width in the rear fenders, a sill that sticks out to match this fender, a bumpy rear bumper for the same reason, and 25mm more metal in the rear wheels (or a 25mm spacer for the Cup2) to increase the offset to match.
Yes this topic never gets old
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
![Group Hug](https://rennlist.com/forums/images/smilies/grouphug.gif)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#123
Buy the wide body. You know you want to.
#124
Baby Got Back … gotta love that thick booty!
#125
If I understand your question 100%..... there is no difference between the cars at the front.
Yes this topic never gets old![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
#126
This is true!!! Was set on a WB C2S until I looked at the proportions…
NB C2/C4 is more balanced, ie. Porsche should have increased the C2/4S front fenders width….They did not for cost control I’m told.
Subjective still, but have a look and most will get what I’m talking about. If you’re all about the rear view only without looking down the side of the car then, you’re good….
Objectively, who has the measurement for front fender width/track comparing C2/4 with C2/4S?
your smokin’ crack …. Line them up NB and WB side by side… WB all day long
The following 2 users liked this post by Peter65:
coreseller (05-13-2023),
FLYT993 (05-07-2023)
#130
the WB's were originally meant to be Turbos- the WB's larger offsets and larger tires were designed to keep the rear planted with 450 Hp surging through that little car. the C4S was a "parts bin" car- a lot of turbo parts thrown into the TT body. I honestly don't know how the C2S came about unless it had something to do with fewer 4wd systems, Big Reds and Booster pumps for the brakes, but still had bodies to use? Either way WB for the Win!!!! And for me c4s all day long.
#131
The correct answer is neither.
The superior body is of course the RSR, which starts as a NB and adds flares to both front fenders and rear quarters thereby keeping the proportions just right and widening the front and rear axles by the same amounts.
If you are a WB fanboy then the GT2 does the same but starts with the already widened rear quarters of a TT, somewhat losing the perfect proportion but gaining maximum width.
Jlaa (05-13-2023)
#132
All 993's are wide in the hips and butt, just that the 2S and 4S are wide...r.
The widened Guntherwerks front ends, adding a bit to the discussion, for some here are too wide and throw off anterior proportions.
