993 First time on my lift (PICS)
Today I had some alone time to take a look under the 993, the underside was perfect, no rust, no oil leaks. I also removed the cassette storage and upgraded to a storage tray. I also installed my new/old CDR 220. I also installed a new license plate bracket which I purchased here on Rennlist. Here are a few pics of the car on the lift:
![](https://lh6.googleusercontent.com/-aQWlj6F7TxM/UPt1gSldn8I/AAAAAAAAECc/0hhE5ehI-nE/s1024/2013-01-19_16-49-16_151.jpg)
![](https://lh5.googleusercontent.com/-zOkP8qriYIE/UPt1b01SveI/AAAAAAAAEB8/CSa3XqTs6xQ/s1024/2013-01-19_16-47-16_848.jpg)
![](https://lh5.googleusercontent.com/-1h6bj7OyER4/UPt1DUV0RiI/AAAAAAAAEB0/SRygA7T9Oew/s1024/2013-01-19_16-47-40_49.jpg)
![](https://lh6.googleusercontent.com/-FTGYIS1Lrck/UPt1dykPiuI/AAAAAAAAECM/427k9bBrP20/s1024/2013-01-19_16-48-10_149.jpg)
did you take some panels off from underneath to get a better look? My next house will have something with a lift, I took the front end off my mini, but its a small singe car, enough space to get it up on stands, but its tight!
phil.
phil.
Very nice shop space Mike! I like the antique Toyota (FJ?) in one of your pics, note the vintage 4Runner in the background below. How we ever got along without lifts is a mystery...
![](https://rennlist.com/forums/members/sdoolin-albums-my-rh-wheels-picture20043-dsc01917-800x600.jpg)
Thanks!
Thanks, If you are a wrench head like me you definitely need one.
Thank you!
Thank you. Us gear heads always need a lift. No pun.
No I didn't but will now that you mentioned it, thanks.
Thank you!
After many years, since age 16, of crawling under my cars using hydraulic jacks and jack stands, etc., now at 60 YO I decided no more crawling. I will continue to work on my cars until the end so having the proper tools available is paramount.
There are so many different types of lifts available these days, scissors lift, mid rise, four post, etc., however, the prices are reasonable enough to own one according to your ceiling height limitations. Oil changes and mechanical work is a breeze with a lift, as you already know.
Thanks again,
Hi Mike,
Great you finally installed a lift! Floor jacks and jack stands certainly do get old. How do you like the specific lift you have, and if I may ask, what model is it? I'm a few weeks away from pulling permits on building a detached garage and am definitely installing a two post lift. I've been looking at several lifts and Atlas is one of them.
Shawn
Shawn
Hi Mike,
Shawn
Shawn
The Atlas lift works great, the installation was a bit of a challenge, I will attach a few pics, I had couple of friends over and one had an excavator which lifted the two post upright. Once the lift was upright then measuring, leveling and securing it to the concrete was a piece of cake. If just getting ready to build a shop make sure to have the concrete thickened to six inches and add re-bar where you are planning to install the lift. A 4 inch slab will work, however, I over designed it to be 100% sure, rule of structural engineering.
I purchased mine from Greg Smith equipment, (http://www.gregsmithequipment.com/) Atlas model number 90HSC 9,000 pound asymmetrical lift, and reasonably priced.
Please let me know if you have any questions and I'll be glad to help while the whole process is still fresh in my mind. I assembled the lift using an engine hoist to to move the columns in place and bolt together. PM me and I can give you my number.
Here are the installation pics:
There are a LOT of affordable options these days, I don't wanna HiJack your thread so if anyone wants more info on my set-up (sq ft, height, air delivery, water, heat, etc), PM me and I'll provide details. Maybe we need a thread just for shop pics and details (it probably already exists).
Good for you Mike!
Hi Shawn,
So I am going to throw these cylinders away and look for a better quality set - there are some restrictions about sizing and piping, so the search might take a bit.
Other than that, the carriages/arms/columns are good and strong, and the motor/pump is good (Motor is US made I think).
Cheers,
Mike
