Advice on Brake Pad Sensor Wire Please
I realize the importance of brake pad sensors and why they're needed for some drivers. For the rest of us car nuts, are they really necessary? On my car, the front sensors came out really easily. The rears, however were like pulling teeth to remove. I know there's a DIY here for sensor delete. I'm not looking to delete the sensors. I was thinking of not attaching them to the pads, and just zip-tie them out of the way. Any harm or will it trigger brake pad warning? Thanks
I don't use spiders or sensors. I have my sensors tied back behind the calipers. It will take a few years for my pads to wear out, so I don't worry about it. Plus I periodically check them. OEM rotors and Textar pads....no squeeking.
It makes swapping pads easier as well.
I don't use pad sensors or spyders either, to prevent an OMG light(!) you need to cut the sensor wire and splice the ends together so that there is a continuous circuit, then tie wrap the ends out of the way.
Show-off
Gotta love that blue!
Noob here....so tying the sensors to the back of the calipers will trigger warning, unless I splice them? Thanks
Gotta love that blue!I don't use spiders or sensors. I have my sensors tied back behind the calipers. It will take a few years for my pads to wear out, so I don't worry about it. Plus I periodically check them. OEM rotors and Textar pads....no squeeking.
Leave the plastic end plugged into the chassis wire, cut the wire between the plastic connector and the pad, splice the ends together, seal w/ shrink wrap or similar insulation.
another option is to pry the spyder off the pad and discard
coat the edges of the pads w/ Optimoly or similar Cu based high heat lube, I use a Wurth equivalent myself
The sensor is a plastic piece that wears thru if the pads are too low. A good sensor left intact is not an open circuit and will not cause a warning light. I have run mine this way for years with no issues. If you currently have the warning light, then your sensor is toast and you will need to cut/solder the wires together, otherwise just wrap it up behind, no cutting or soldering necessary. If you ever want to change back, just unwrap them and put the sensor back in the pad.
It's a $10 dollar part.. sooo
1. keep it in and you have an all up $40 of safety incase you miss something on your regular checks
2. more material on your breaks = better cooling! :P
* I can't wait to drive home.. drove the 993 today
im addicted :P
phil.
im addicted :Pphil.
