993 Forum 1995-1998
Advice on Brake Pad Sensor Wire Please
Old 12-06-2011, 06:13 PM
TheOtherEric
TheOtherEric's Avatar
Ditch the sensors if you don't need them. Cut the wires right up next to the plastic plug, then solder the tiny stubs of wire together and cover up with JB Weld or some such epoxy or glue, or heck nothing. I did that years ago and never once thought about wear sensors since. I swap street/track pads regularly so there's no risks for me.
Old 12-06-2011, 07:29 PM
Jeff96-993
Jeff96-993's Avatar
I snipped the wires too, and just twisted them together. 9 years later the twists are holding fine.
Plus I'm saving the 3 ounces of weight.
The car spends 2 months up in the air for my tinkering enjoyment, the pads get checked then. I don't need the sensors.
And the weight savings part was just a joke... if my sensors were in good shape when I pulled the pads for my first brake job I'd likely have tie-wrapped the entire thing back like others mentioned. They were in bad shape, so I cut the wire and called it a day.
Old 12-06-2011, 08:06 PM
P-daddy
P-daddy's Avatar
Trust me $40 is not the question here. I've spent $$$$ on this car in mods already, and I'm not done yet. For those of us that constantly tinker with the car every other day, I highly doubt the pads get overlook. I posted the question to see if I can leave them off without triggering warning light. At my current rate of use, my pads will be good for at least 10 more years
Originally Posted by element
It's a $10 dollar part.. sooo
1. keep it in and you have an all up $40 of safety incase you miss something on your regular checks
2. more material on your breaks = better cooling! :P
* I can't wait to drive home.. drove the 993 today im addicted :P
phil.
Old 12-06-2011, 10:40 PM
kjr914
kjr914's Avatar
You need to do some autocrossing or a few track days. That will take care of your slow pad wear...
Old 12-06-2011, 11:00 PM
Ed Burdell
Ed Burdell's Avatar
I soldered and tied my sensors back a few years ago after one failed and gave me a false positive for brake wear.
As for the spiders, having lived with ungodly squeal during this past set of pads and rotors (pagid blues and zimmermans) I went full OE this time, including spiders...I chickened out of deleting them, in other words, lol...
Old 12-06-2011, 11:18 PM
Renaud Bizet
Renaud Bizet's Avatar
You too !!!
I have ran paged blue on OEM rotors for the past 6 months and drove people crazy with the squeal.
Now that they wore off a bit I was able to put the spiders in but the squeal is not completely gone.
I still get dirty looks at stop signs or red lights
I think next time I might go OEM, but I really like the bite of the pagids.
Old 12-06-2011, 11:45 PM
jscott82
jscott82's Avatar
+1 solder and seal
Although..... I kinda like the look of the little red accent on top of the caliper, Id keep them if they are not in your way very often.
Old 12-07-2011, 12:01 AM
P-daddy
P-daddy's Avatar
And don't forget tires too, Keith
Old 12-07-2011, 11:14 AM
mcipseric
mcipseric's Avatar
does anyone take off their engine tray?
Sorry..... I am feeling a little punchy this morning
Old 12-07-2011, 11:36 AM
FisterD
FisterD's Avatar
I never touch my engine tray. It stays right on the shelf were it belongs.
Old 12-07-2011, 12:26 PM
AOW162435
Seared
AOW162435's Avatar
I'm looking for one (or 4) of these to try something with. If you've removed your sensors and are on your way to the trash can with them, let me know.
Andreas
Old 12-08-2011, 11:28 AM
AOW162435
Seared
AOW162435's Avatar
Bump.
Andreas
Old 12-08-2011, 11:34 AM
Quadcammer
Quadcammer's Avatar
Received 1,414 Likes on 816 Posts
can I ask why you'd remove these? They only do something when they need to, weigh practically nothing, and are dirt cheap.
I just don't see the point in removing them.
Old 12-08-2011, 01:08 PM
TheOtherEric
You're not thinking hard enough.
Ever track your car?
Old 12-08-2011, 01:24 PM
Falcondrivr
Falcondrivr's Avatar
What eric said.
Mine were constantly crumbling every time I changed my pads (a lot) and wouldn't fit snugly into the pad anymore. The little metal clips would break off too. So I tied them back out of the way. Problem solved. I change pads so frequently that I can tell when I need new pads anyway.
Quick Reply: Advice on Brake Pad Sensor Wire Please
