993 Forum 1995-1998
Tiptronic Supercharger Project - data logging begins
Old Jul 6, 2012 | 12:10 PM
  #226
TheOtherEric's Avatar
TheOtherEric
Originally Posted by haygeebaby
...I need to talk to Todd a bit more to see what type of tuning we have set. But it is Proto turbo stage 2 timing I believe. ...
ha ha, I certainly hope that's not true. I'd expect Todd is giving you customized tuning for your setup, which is definitely not the same as a Proto TT stg 2. I wouldn't dream of running a s/c with TT stg2 tuning even for 2 miles. You should have sent him plots of power, tq, boost, and AFR. Each of those 4 things is needed or he won't be able to do his job properly. It's easy for him to tweak his tuning, so he should give you a customized chip. That's how he and I worked together. Anything less and you're playing with a grenade.
Old Jul 6, 2012 | 09:05 PM
  #227
Eric_Oz_S2's Avatar
Eric_Oz_S2
I haven't seen any plots of AFR on this thread. Have you checked they are 11.5 or richer at WOT? Fuel is critical. To some extent the WOT timing will look after itself as the knock sensor will instruct the DME to pull timing which is OK in the short term. But, this will also mean the power curve is more unstable. Normally you would check this on a dyno. At the very least the timing should be retarded above 3 to 4 psi boost, linearly with the increase in boost.
Agree with the other eric
Old Jul 7, 2012 | 05:53 AM
  #228
haygeebaby's Avatar
haygeebaby
Sorry - Protomotive stage 2 turbo system software with stage 1 timing - that's what it is.
I figure I need some guages to monitor things properly. So more to come soon.
Seats finished. Hope fully steering wheel next week and I'll be talking to the auto trimmers next week.
File Type: jpg
File Type: jpg
File Type: jpg
Old Jul 7, 2012 | 06:26 AM
  #229
MPB993's Avatar
MPB993
Hi haygeebaby,
its been a while but thought I would chip in. For me removing the chargecooler and adding the a/w was a big step forwards in responsiveness as well as reduced SC power required to push the air through the chargecooler. The SC runs cooler. Before I ran a/w after the SC now I run it before the SC (40k miles no issues). Its a great way to go on our tips. Also the cold air intact reduces IAT and head temperature leading to retard in stop start traffic. Its not that hot here but still worth while. Retard is really bad for our SC head temperatures :-(. I've also done some fluid modelling which shows that for each bend ahead of the SC we lose about 1/2lb intake pressure at full power/high rpm. I couldnt change the SC intake due to space but I have straightened everything ahead of the throttle to get a little extra air in :-)
I really recommend a cold air intake, its made so much difference on mine.
Done all this at about 35k miles a few years back and now at about 100k, still brings a smile to my face everytime I hit the pedal.
Now at the point that I dont watch the detonation output from the ECU on each run and just keep an eye that the w/a bottle still has fluid in it :-)
Just thought I would share my experience.
Cheers, Mark.
Old Jul 7, 2012 | 06:45 AM
  #230
haygeebaby's Avatar
haygeebaby
Thx Mark. Nice to hear from you again. I read through your threads before I decided to take off the charge cooler. I can confirm some of your findings as well.
What I'm looking for is a nice air box.
Anyone know where you can get this for a cheaper price?
http://www.gmpperformance.com/index....ail&PID=203179
Old Jul 7, 2012 | 12:55 PM
  #231
haygeebaby's Avatar
haygeebaby
Mark
Question for you mate - I'm looking at a pic of your configuration. Your setup does not have the intake elbow on it. What did you do with the ISV? What do you have configured between the throttle body and the air filter?
TIA
Ken
Old Jul 7, 2012 | 02:37 PM
  #232
TheOtherEric
I figure I need some guages to monitor things properly. So more to come soon...
I think you missed my point and those of Eric_Oz_S2. You shouldn't drive ANYWHERE until you've verified your AFRs and such on a dyno. Todd's off-the-shelf programming is not sufficient, period. Too many variables. BTDT.
And I have to wonder if you have a fueling problem after killing your spark plugs so quickly.
Old Jul 8, 2012 | 03:39 AM
  #233
MPB993's Avatar
MPB993
Hi Ken,
I created a feed before the throttle body into the ISV but after the afm and put the ISV above the SC intake on a bracket. I also have the IAT sensor before the throttle body. Of the various other pipes that fed into the elbow all feed into the same pre throttle point besides the oil tank breather which I have chosen to vent as per RS cars I believe?. Others have had issues with sump pressure on turbo'd cars so decided not to take a chance with a catch tank.
Sorry about the picture its the best I could take.
Forgot to say before I've not tried this with a 2.4" pulley (not sure I would go there) but currently running a 2.6" pulley on standard ecu chip and TPC software with my own 7th injector numbers. Due to cylinder AFR variations with the single 7th injector I maintain an average 12 AFM on the LM1 WB. I get about 1/2 AFR difference between the banks which you can see on the LM1. Cannot desern between cylinders as expected but I tried to avoid any one cylinder going into the 13s. Checking my spark plugs they are all near the same temperature and colour without any signs of detonation.
Mark.
File Type: jpg
Old Jul 8, 2012 | 05:36 AM
  #234
Timspu's Avatar
Timspu
Hi Ken,
If you havn't bought one already , i would recommend at a minimum an innovate LM-1 AFR data logger. The latest LM-2 would be the best. With these you can plug in RPM and boost and log it all. ( Will end up cheaper than dyno sessions in the long run)
I am using a LM-1 on my 930 Turbo to adjust my fuelling, it works very well and gives you the comfort of knowing you are not running lean (12 AFR and above.)
If i may chip in and say hold off on the extra mods with the SC, get it set up properly first with the right AFR's, then add in your water injection, intercooler etc. Yes this will be more expensive, but if done stage by stage with a known quantity from the start you will be able to identify any issues and also note the mods that give benefits.
With your current set up without water meth and standard pulley my 993 did pull 355 flywheel BHP, this should atleast be a starting point. Without the intercooler i had 340 bhp but was running rich, the intercooler helped the richness and added BHP without the additional tuning. The Uni Q was not all that good.
In the end i had a tuner who used an emulator and adjusted my Motronic ECU to get the right fuelling, it wasn't perfect but it was much better than the Uni Q as it was done on the road whilst driving not on a dyno. (Uni Q was still in line and motronic was adjusted to give the better Fuel map)
All this with standard fuel regulator and standard injectors, my fuelling was 11.9 AFR at its leanest. The car ran strong with no issues at all.
Good luck Ken.
TIM
1988 930 Targa Turbo
Old Jul 17, 2012 | 08:46 AM
  #235
haygeebaby's Avatar
haygeebaby
Yo Tim - great to see you online. I got a Zeitronix ZT-2 kit with the works sitting here right now waiting for install. I will get it installed with the RS carpet that has yet to be ordered. Hope all is well with the turbo.
Steering wheel installed. But forgot to order the tip harness for a 94 car.
File Type: jpg
Old Aug 17, 2012 | 01:32 PM
  #236
haygeebaby's Avatar
haygeebaby
Some updates in the last few weeks.
Dash, door trim, and rs door panels ready to be sent off to be covered in black alcantara with silver stitch.
Finally installed the tiptronic harness for the flappy paddle steering wheel. The steering wheel has been a great addition.
Zeitronic unit installed. Boost and AFR modules connected. Still have to do EGT and 2 air temp sensors. But will need some custom pipe work to be made to get this completed.
Here is some interesting data - running the 2.4" pulley and not having the charge cooler installed - I have seen 13psi. The new setup will have custom pipe work and a new and improved charge cooler and meth injection system installed. I hope to see around 7 to 9 psi with the new configuration. 13psi is a little too high.
RS carpet has been ordered and I think I might get one of those porsche retro decks and ditch the alpine unit which looks a little out of place at times.
Car is also booked in to a performance transmission expert next month who will upgrade some internals and strengthen things as well.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Sep 3, 2012 | 11:22 AM
  #237
Timspu's Avatar
Timspu
Ken,
Like what you have done to the car so far, love the steering wheel.
Is there a company Aus that sells the barrel intercoolers? I think they are made by PWR. These look quite trick and have heard good results from them.
http://www.thor-racing.co.uk/Charge_Coolers-291.asp
930 Turbo is running great thanks, having new headers fitted tomorrow.
cheers
TIM
Old Oct 13, 2012 | 01:30 PM
  #238
haygeebaby's Avatar
haygeebaby
The RS carpet is almost done.
The alcantara covered parts have been at the upholsterers store for over a month.
I just havent had the time to even pick them up or check if they have completed them.
New larger more efficient heat exchange going in soon. Same setup as Marc Shaws - which I think is the most efficient setup I have seen.
Custom made pipe work for the chargecooler scheduled for this month.
Bungs for additional meth injector and two air temp sensors are going in with the pipe work.
Also new carbon air filter going in.
File Type: jpg
File Type: jpg
Old Oct 20, 2012 | 02:51 PM
  #239
haygeebaby's Avatar
haygeebaby
Door panels installed now.
Centre console to do next.
Front dash is waiting to be covered.
Next is custom pipework for the SC chargecooler unit and installation of the new heat exchange.
File Type: jpg
File Type: jpg
File Type: jpg
Old Apr 19, 2013 | 10:27 AM
  #240
torseilertsen's Avatar
torseilertsen
Hi!
Great looking car. I was thinking about the TPC kit myself, and finally found one whos done it on a tip!
I wonder: can the tip take the extra heat and power?
Check out these guys http://www.ashcroft-transmissions.co...d&productId=51
Did you do any reinforcement on the tip like the 22 -> 24 upgrade shown?
My thread:
Tor S.
