Tiptronic Supercharger Project - data logging begins
Tiptronic Supercharger Project - interior almost done
Well guys - after 6 years of 993 ownership the slippery slope has led me to this project. We don't see a lot of supercharged tiptronics so I hope this post is a treat for others out there.
This is what the project consists of:
Base TPC Supercharger kit with an Eaton gen 4 supercharger
Custom chargecooler similar to TPC unit
Protomotive stage 2 turbo system software with stage 1 timing
Protomotive mass flow expansion network
36lb fuel injectors
Snow performance meth kit (later in the year)
The goal is to get some more power into the tiptronic ROW C2, in a sleeper package, that will increase the grin factor. This will not be a track car - 99% street.
During this project we have also changed the chain cover gaskets. Let's hope the leaks finally stop. I also have 6mm wheel spacers to install once the car is put back together. The garage is a mess right now and the car is in pieces.
I've been working on the project for about a week now - a few hours each day. I've managed to get most of the core parts installed, and what's left now is the vac hoses and pipes, and the chargecooler install.
Here are some pics for you guys:
36lb fuel injectors
Cool project. How's the belt alignment? When everything is in place, the belt tension will tend to pull the supercharger snout toward the fan. Some have experienced slight rubbing betwen the belt and fan housing.
Calvin
I believe the system is running at 6psi. This is my first SC and I'm still learning. How and where would you adjust the psi level? Is it software based or mechanical? Is the psi on a SC determined by the pulley size? I think I'm running a 2.6" pulley.
Axl
Yeah - pulley is pretty dam close to the fan housing - like 1mm or less. I need a big **** adjustable wrench to leverage the tensioner so I can get the belt on. I would not be surprised if the tensioner pulley rubbed on the fan housing. Got any tips on this?
Ed
The engine carrier does have the extra layer of welding. My car is a first generation 1994 model, so I would be surprised if other 993's didn't have this. Don't all 993 have this?
Chip
Not touching the transmission. Haven't read anything that says it cannot cope with the SC - but then again - very little to read about tips and SC. I have a feeling that the bullet proof tip will not have a problem handling the mild increase in HP.
Axl
Yeah - throttle cable placement for this project is interesting. I did not like the part where you have to cut off the metal connector on the throttle body for the cruise control cable mechanism. You have to do this otherwise the throttle body spring mechanism does not clear the rear of the engine body. Lots of little things are left out of the TPC instructions.
The "L" shaped metal stop needs to go behind the engine sheet metal. I tested the length last night and I've got it about right. Throttle body opens 100% when accelerator pedal is to the floor. I'm not too keen on the setup, but it does work. Looks like they have a simple solution for this that works. And simple is good. But having to check it ever so often would be a bit of a hassle.
Mike
Whenever I saw someone post a thread about a SC install - I too wanted one badly. I can't wait to see what the driving impressions are when the project is completed.
Axl
Ed
Chip
Axl
Mike
I was thinking of doing that. But the thing has a fair bit of tension in it, so I decided to get something that will hold on tightly. Big **** adjustable wrench came through.
Is you pulley wheel as close to the fan housing as this?
Got a problem boys - maybe the guys who have a TPC SC installed can help me out. Not too sure where some hoses need to be connected to.
On the gen 4 TPC setup there are 3 barbed connections.
A - small (3/16) barbed fitting on the inlet manifold elbow before SC
B - large (3/8) barbed fitting on the inlet manifold elbow before SC
C - large (3/8) barbed fitting on the intake manifold
In the picture - top of the bronze frame - I believe is the fuel pressure regulator? Where does that get connected to? A or B or C?
I seem to recall:
A & B - are for vacuum sources. Use these for the various vacuum connections such as tank purge vent, AC flapper, vram actuators, brake booster, etc.
C - this is for the fuel pressure regulator and to the boost gauge or the boost sensor used by TPC to activate the injectors, but not sure...gotta a pic?
You will proably need to figure out all the vacuum requirement & connectors for your car and then decide with of the A or B vacuum source to hook it up to and how.
Don't get the vacuum & boost connection mixed up...otherwise you will do nasty things to your engine!!!
In your picture, the top conector is actually the tank vent/purge valve. That plastic housing with an electrical connector is a 1-way valve used by the car (vacuum which feed into the intake assemby) to suck fuel vapor into the intake. The engine actually monitors this and will throw a check code if it is not connected or working properly. The fuel pressure regulator is actually attached to the fuel rail on the left hand side of the engine.
