How long does the 1995 Porsche 993 engines last?
#32
This is an old thread, but that won't stop me from commenting. I wanted to mention that engine longevity is also related to your driving style. If you do a lot of cold starts and short drives where the engine is rarely brought to full operating temperature, or you take little care with driving gently until the engine is fully warmed, or if you rarely take it near to the redline, your longevity will probably suffer.
#34
Moving to shop 2, when I was mainly picking all the 2.7 cores I could find to piece this and that together + doing the valve guides so that I had an affordable alternative to keep he 2.7 cars on the road, I usually never had to throw anything away but a crank that couldn't be reused as standard or high mileage Alusil barrels, unless the thing was run out of oil.
#35
Interested in your opinion since you've opened up so many air-cooled engines, and I always wondered with the threshold number is on a 3.6 that holds 12 quarts of oil...
#37
Ken, I'm curious since our 993s hold, what, 12 quarts of oil, how many quarts low on oil would need to be missing before damage might occur? In other words, I know our cars would be fine running low on a quart or two, but when would damage start occurring? Running 5 quarts low? 8 quarts? 10?
My belief, on the old 2.7s (and some 2.4s that ran hot in AZ) was that low oil pressure at 250F+ was more of a killer. Some of the things barely ran 15psi @ 3K under those conditions. By comparison, I think any of the aluminum engines (3.0-) are indestructible if you even pretend to regularly check the oil. (At least everything from an SC on had a minimum of a trombone cooler up front.) But that could be only 5-6K with one of them with bad guides, and burning a quart every 6-700 miles.
#38
#39
#40
Received 1,022 Likes
My 95 is just over 18 years old and has about 83000 miles. No drips in the garage and doesn't burn oil as long as its exercised.
My 97 is almost 17 years old and has 86000ish miles. In the 5 years and15000 miles I've owned it, I've only had to add 2 litres of oil between the 4 oil changes I've done.
#41
In addition to oil consumption, an oil analysis will give you some insight into the health of your motor.
http://www.blackstone-labs.com/
#42
Hi
I took my motor apart at 186k miles for a broken piston ring. The guides were shot, but the rest of the engine was in excellent condition. Before the rebuild although the guides were worn the car did not use much oil or smoke on start up. I think regular oil changes is the most important factor especially for cars used for frequent short journeys.
Berni
Berni
