993 Forum 1995-1998
Engine undertray
Old Nov 5, 2010 | 12:39 PM
  #31
cgfen's Avatar
cgfen
Originally Posted by Linnm
Bruce Armstrong thinks it is a good idea to remove it. That is good enough for me
Well Marvin the Martian and Adam Ant think so too.
Bruce Armstrong?
Definitive thread here.
https://rennlist.com/forums/993-foru...s-no-good.html
Old Nov 5, 2010 | 01:18 PM
  #32
AM993's Avatar
AM993
Anyone needs an engine tray? I have one sitting in my garage
Old Nov 5, 2010 | 01:23 PM
  #33
TRINITONY's Avatar
TRINITONY
For winter driviing I'd leave it on, and for summer take it off.
File Type: jpg
Old Nov 5, 2010 | 02:46 PM
  #34
FisterD's Avatar
FisterD
I have a bunch at the shop. Please feel free to come by and pick one up.Free decal included with every engine tray...this month only!!!
Old Nov 5, 2010 | 02:50 PM
  #35
Mike J's Avatar
Mike J
And I did not know there were worth money...just tossed 5 into the garbage!
Old Nov 5, 2010 | 02:52 PM
  #36
Dudley's Avatar
Dudley
Originally Posted by goofballdeluxe
Umm, no one bottomed out, per se. At least not in a way that would damage anything had the engine tray been on, which is the point. With the engine tray removed, the heater boxes can droop down ever so slightly. All one needs to do is back out of a driveway and the box can catch and rip off, as that's what happened to me.
The engine tray in place would have prevented this. An advantage to having the engine tray, as it came from the factory, on.
+1 One of members cut openings in the cover and added wire mesh to the openings.
This sounds like the best option.
Old Nov 5, 2010 | 03:10 PM
  #37
Marco8's Avatar
Marco8
+1 Me too
  #38
goofballdeluxe's Avatar
goofballdeluxe
Agreed. I saw the pics of that mod, and I think it's the best solution
Old Nov 5, 2010 | 04:10 PM
  #39
grappamon's Avatar
grappamon
Aerodynamically it won't function as desinged if you start cutting holes in it. P/a will be reduced and therefore reducing it's ability to effectively evacuate air from under the car which helps produce downforce. You are essentially changing the air pressre under the car and that has a negative aerodynamic effect at high speeds. But then if you're a parking lot warrior you probably don't care about high speed stability.
Old Nov 5, 2010 | 04:45 PM
  #40
MarkD's Avatar
MarkD
if you reach the 993's maximum speed you might see the effect of the undertray's contribution to the car's aero.
might...
an undertray thread... a certain sign winter is near (or arrived in some parts )
Old Nov 5, 2010 | 05:05 PM
  #41
TX Silver's Avatar
TX Silver
I just want the tray to match the air box.
Old Nov 5, 2010 | 05:14 PM
  #42
timothymoffat's Avatar
timothymoffat
Mine are off on both cars. I have however mounted one of the discarded engine trays on the roof, angled down at the front. Hopefully this increased downforce will cancel any lift I've created by it's removal from under the car.
Old Nov 5, 2010 | 06:16 PM
  #43
aribop's Avatar
aribop
Darin,
Would you be willing to ship one to me? I'll pay shipping of course. I have an idea but need a spare tray for research.
Albert
Old Nov 5, 2010 | 06:34 PM
  #44
IXLR8's Avatar
IXLR8
might...
What about synthetic oil?
Old Nov 5, 2010 | 07:16 PM
  #45
Paul902's Avatar
Paul902
I was just going to say...If I follow the DIY for installing the engine tray, should it be Brad Penn or Mobil 1 dripping on the tray from my leaky valve cover??
