Engine undertray
#181
Agree that this is the best engine tray thread of all time! No argument on the reduced drag and minor ground effect advantages with it on....at high speeds. Newer 911s don't have em, 993 factory racecars didn't have em, and my car doesn't have one. If someone can prove having one on will keep things cooler under the typical driving conditions I experience then I'd put it back on (that is if I hadn't thrown it and the rear attachment bracket in the trash!). Since I don't plan on testing the engine temperature theory for MY driving conditions it's staying off. If I ever need more downforce I'll go ten an RS tail.
How many posts are we at now gents? Keep it going!
Ps was it an airplane, us missle, or foreign missle launched off the Cali coast several days ago? Experts saying airplane...yeah, and that airplane flew out of my *** then out over the ocean. Who dunnit?
#182
Ahhhh. Good'ol Rennlist...
#183
To satisfy my own curiosity, I'll be doing my own tests next summer recording the CHT with and without the undertray with respect to ambient temperatures. I'll verify CHT accuracy in our temperature & humidity standards lab.
I'm not going to buy that overpriced Porsche CHT. Does anyone have the thread specs (diameter and pitch)? I'll make my own CHT.
They have years (even lifetimes) of experience with these cars and engines and they share their real world experience with shade tree's like me. I hope that they will continue to share their experience based opinions.
As for the "PROVEN DISADVANTAGES" of running without a tray mentioned earlier. They are the result of improperly adjusted heater flapper boxes. If the owners would have taken the time (apx 2 minutes) to properly re-adjust the boxes no damage would have occured to the boxes. I have drug muffler tips, rear bumper lip and scraped a heat exchanger without any damage to the boxes. Properly adjusted they are at or above the heat exchangers.
My car has 93,000 miles is aero stable to 145 mph, uses no oil and the oil temp stays in the 8 o'clock position without a tray. Results are good enough for me.
DO WHAT YOU WANT IT IS YOUR CAR!
#184
Shouldn't someone have proven that taking it off makes things run cooler or makes valve guides last longer?
I sometimes wonder how these ideas start up. The same thing happened on the BMW motorcycle forum where BMW NA via someone started a belief that only a BMW battery charger could keep a BMW battery charged.
#185
Whoever came up with the idea should back it up with something. If I made a statement like that, I would only do so based on measurement data and if someone asked, I would not get bent out of shape being questioned. Till now, nobody has done so. I know its so taboo to question anything these days.
BTW, your voltage is low.
#187
I'm no engineer but my logic would be to put my money on those engineers who have spent years learning about and working on these engines...like the "so-called gurus" on this forum. But hey...we all have the option to choose what flavor of koolaid we want to drink.
#188
Certainly not worried about 0.2C or even 2C, but I'd have to check it. That is what calibration is all about.
#189
You're absolutely right. But then I don't have to believe them either. I'd at least state "why" and "look at what I discovered" before making a statement.
Porsche has no engineers?
I would guess we work in different environments...I work in labs, so we don't just assume everything. We take measurements and collect data. When I used to work on aircraft, I just didn't assume everything was fine and hand it to some poor owner. I'd test fly it myself to make sure everything was OK and then hand it over.
Next summer, we...well at least I, will know the mystery of the engine undertray. Should be fun...looking forward to it.
#192
No need for sarcasm. Yes, they have engineers. The same engineers responsible for weak valve guides and SAI ports that clog up, among a number of other brilliant designs. However, since these cars were designed 16+ years ago, those engineers are probably not around to answer our questions regarding the engine tray. However, there are several techs who have worked on these cars during that 16-year period who are probably better qualified than the original engineers in opining about what actually works and what doesn't on these cars.
And please don't get me wrong, I applaud your inclination and approach. I think it's great that you're going to take your time to investigate and attempt to quantify this age old dilemma. This board used to have an abundance of technical posts. I don't find that to be the case anymore. So I too look forward to your findings.
#193
When Porsche engineers, or any manufacturer's engineers, design parts that evenutally amount to making of an entire car, they run "test beds" to see if the part actually works as designed. If the part works as designed, it enters into production.
Upon cars being sold, sometimes parts as designed don't stand up to real world use as designed and a recall is issued, or at the very least a service bullentin is issued, so that a defective part can be replaced by a better designed part or a recommended procedure advised (ie: remove engine tray).
In regard to the engine tray, has this happened?
Irrespective of that, it appears we have persons here onboard that have real world experience and have issued advice based on that. So removing the engine tray based on that is fine if other persons have experienced the same thing or just being cautious.
But on the flip side, if IXLR8 wants actual proof, then that's fine too. No need to undermine his desire to obtain proof because it has been expressed that there are a number of "factors" that could lead to issues on the engine with the engine tray in place but not necessary directly linked only to the engine tray in place.
Bottom line, its your car, do as you please.
#194
The "leverage" may have been faster access to the engine during a race if a "racing" 993 needed service on the engine.
#195
"Ps was it an airplane, us missle, or foreign missle launched off the Cali coast several days ago? Experts saying airplane...yeah, and that airplane flew out of my *** then out over the ocean. Who dunnit?" (2ndof2)
IMHO - Chinese or NK missile launch from a sub.
