Momo horn help please
Ok, so I've read what seems to be every post on the subject and am still trying to figure this out.
I've put in the 964 part (964 652 104 00) and have connected the brown wire with the white stripe to it. What do I do with the solid brown wire which also comes out of the orange connector? When I touch that wire to the 964 part the horn sounds, however when I put the hub on the steering column (confirming that the brass ring connects with the 964 part) the wire in the hub (black) does not have power. This is without replacing the washer and nut that hold the wheel to the column.
So two questions: What do I do with the solid brown wire coming from the orange connector and is it correct for the black wire in the hub to not have power?
Thanks in advance for your help.
David
David
David
David
I installed my MOMO wheel last year, so I can't remember exactly, but I followed these two threads for the install:
https://rennlist.com/forums/993-foru...pressions.html
https://rennlist.com/forums/993-foru...-long-dyi.html
I hooked everything up as stated, and the horn works perfectly.
Good Luck - and if you still can't figure it out with these two threads above, I'll take a look tonight and PM you.
Andy
Thanks Andy, I read those (and quite a few others) many times last night and unless I'm missing it they make no mention of the solid brown wire. I know I'm missing something obvious here, it's probably pretty simple.
A
Thanks very much Andy, much appreciated.
Hopefully this makes it clearer, I've attached the brown w/white wire to the "pin" on this part right where the arrow is pointing and confirmed that it has power. I just want to figure out what to do with the solid brown wire coming from the same orange connector.
I used the method detailed in post #16 of this thread but again it makes no mention of the other wire.
King of Cool
FF, at this point I don't have anything attached to the button but am assuming the black wire inside the hub goes to that.
I couldn't see any way to route the brown wire from the connector to the button, can't get it through the hub.
David
David
Ok, just got done figuring this out.
For anybody trying this in the future, the solid brown wire can just be left without attaching to anything.
My problem ended up being that the 964 part was not making contact with the brass ring on the hub when it was fully seated. It wasn't the "height" that was the problem, it was the "angle". Some fiddling with it and it is working fine now, looks and feels great.
Hi, I've got the exact same problem. So did you connect the 'black' wire within the boss to the back of the horn or the aluminium tab on the hub connector plate? I'll have a look at my 964 part and see if it's making contact. It snaps into the fixing hole though so am assuming it's in the right position????
Still confused...
Still confused...
I'm pretty sure I connected the black wire straight to the tab on the horn button, nothing gets attached to the aluminum ring. It's a royal pain to figure all this out but the steering wheel looks and feels great once you do get it done.
BINGO! David you're a star! The height was good but the angle was slightly off, I gently bent the contact strip at an angle and horn is now working...
