993 Forum 1995-1998
How Many Miles Between Alternator Belts?
Old 10-18-2009, 10:24 PM
993Porsche
993Porsche's Avatar
Default How Many Miles Between Alternator Belts?
Getting close to 26K miles on my alternator belt. Does Porsche have a recommended maint schedule?
Ken
Old 10-18-2009, 10:30 PM
b5audia4
b5audia4's Avatar
I would do by years since the rubber belt can crack with age.
Mine actually broke recently, but luckily got it home. I am no mechanic, but was able to replace all the belts following the DIY on Pcar.com.
Old 10-19-2009, 12:47 AM
David in LA
David in LA's Avatar
I just replaced mine...the last time it was replaced was less than 4k miles ago but it was close to 3 years ago and were cracked due to age and heat...it's not just a wear from use issue.
Old 10-19-2009, 12:57 AM
trophy
trophy's Avatar
I do mine yearly as part of my preventative maintenance. My car is predominatley a track car so it does spend lots of time near the redline.....
Old 10-19-2009, 01:51 AM
NightFlyer
NightFlyer's Avatar
Have any of you guys used the Contitech belts? I just had mine replaced and that's what my mechanic replaced my old belts with.
Old 10-19-2009, 02:06 AM
Mike J
Mike J's Avatar
I only use factory belts, there have been several rennlisters whose ECU picked up erroneous misfires with non-Porsche belts.
Cheers,
Mike
Old 10-19-2009, 02:58 AM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
FWIW,....use factory belts only!!!!!!!
Aftermarket ones create a myriad of OBD-2 issues that will drive you nuts.
Old 10-19-2009, 08:36 AM
ironimages
ironimages's Avatar
Thanks,
Mike and Steve this is good information to have as I will do the belt replacement on my car this winter.
Old 10-19-2009, 08:44 AM
AOW162435
Seared
AOW162435's Avatar
As a humorous aside, I replaced all of the stock, original belts on my 2001 4Runner at 171,000 miles. And they were still servicable.
I purchased the truck new.
Andreas
Old 10-19-2009, 09:53 AM
tj90
tj90's Avatar
I just replaced my OEM belt after 4k miles and 1 year of service!!! The belt was starting to shred on the edge. It did not look good. Belt tension checked out good and I have the pulley update so I dont know why it did not last long. My alternator was sent into Porsche for warranty so maybe that had something to do with it.
Old 10-19-2009, 09:58 AM
need a 993
need a 993's Avatar
Could someone explain why something as seemingly innocuous as a belt would trigger OBD II problems?
Old 10-19-2009, 10:45 AM
AOW162435
Seared
AOW162435's Avatar
I'm in the same camp. None of the explainations have ever resonated with me.
This solution is on my short list:
Andreas
Old 10-19-2009, 12:44 PM
NightFlyer
NightFlyer's Avatar
Steve,
Would these non-factory belts cause problems with an OBD-1 car? How hard is it to replace these belts? I looked on the Pelican website and they sell the Contitech belts as an alternative to the factory ones. If it isn't too difficult I would change them myself though to the factory ones.
Old 10-19-2009, 01:04 PM
BSL
BSL's Avatar
Originally Posted by NightFlyer
Steve,
Belts are pretty straight-forward to replace. When I did mine, the thing that took the longest was fishing out a shim that I dropped down in the engine tray. If not for that, it would have taken about 15 minutes (my tool kit doesn't have the triple square, so I had to work a bit that was almost too long in...).
Old 10-19-2009, 08:36 PM
black ice
black ice's Avatar
Ken
Think beyond maintenance interval and eyeball your belt periodically. A correctly tensioned v belt with healthy alt and fan bearings will last a long time. Very very small cracks on the side of the belt are okay, but if you see big cracks, heat builds up there and chunks of the belt will eventually fall off. If any part of the cover is delaminating or fraying, that's another very bad sign.
I think the Porsche maintenance schedule did not say to change it, but rather to check it every 30K miles. Seems like a long interval...
dave
Quick Reply: How Many Miles Between Alternator Belts?
