993 Forum 1995-1998
new porsche two piece crankcase
Old 06-07-2008, 02:29 PM
pedsurg
pedsurg's Avatar
Default new porsche two piece crankcase
Porsche has recently announced a new two piece crankcase for the next iteration of the 997. Additionally, the much maligned intermediate shaft has been eliminated. Is this design closer to our beloved dry sump blocks or just different ??
Eager to be educated, Jack
Tampa
Old 06-07-2008, 03:19 PM
NP993
NP993's Avatar
All the 911 cases have been two-piece, or at least they all were through the 993, which is as far chronologically as my 911 knowledge runs. Here's one half a 911 case:
Old 06-07-2008, 04:01 PM
pedsurg
pedsurg's Avatar
I believe that the previous crankcase (996 and 997) was four piece.
Jack
Old 06-07-2008, 04:41 PM
Bill Verburg
Bill Verburg's Avatar
911, 964, 993, 996tt, 996GT2&3, 996Cup, 997tt, 997GT2&3, 997Cup, all have verticlly split dry sump crankcases.
normal 996, 997, Boxster et al have a horizontally split wet sump crankcase
normal 996 or 997, you can't see the internal crankshaft girdle and supports, above the c/c is a horizotally split p/p section
here you can see the c/s girdle
Gt3 or Cup, the c/c is 964/993 compatible
Old 06-07-2008, 05:28 PM
pedsurg
pedsurg's Avatar
thanks bill. so what does the two piece crankcase mean for next year's 997. Does this represent a significant improvement ?? it sound like like a horizontal split vrs a vertical split makes a big difference.
Jack
Old 06-08-2008, 11:04 AM
pedsurg
pedsurg's Avatar
Bill: Is the elimination of the intermediate shaft significant ?? It is reputed to be problematic in 996's; what about 993's ??
As always, thanks
jack
Old 06-08-2008, 12:05 PM
Mike J
Mike J's Avatar
There is nothing wrong with the intermediate shaft design as far as I know other than a tendency to have a bit of wear on it bearings. It is a bit of extra mass for the engine to turn but this shaft is used to drive both the oil pump and the camshafts. The design comes from the very early days at Porsche so it has to be good, right?
Old 06-08-2008, 12:55 PM
Bill Verburg
Both designs have an intermediate shaft
the wet sump IMS design seems to be flawed as there have been many issues w/ it
like this
The older dry sump design is quite robust and has had few issues. Eventully the bearings and gears will wear/
This is a dry sump IMS
[IMG][/IMG]
Old 06-08-2008, 03:32 PM
pedsurg
pedsurg's Avatar
Thanks again Bill; keep the great pics coming. What can/should one infer by the elimination of the intermediate shaft n the 09 997 ??
Jack
Old 06-10-2008, 07:35 PM
pedsurg
pedsurg's Avatar
So does this new case and the other noted changes represent a migration to the robustness of the dry sump system away from the "problematic" wet sump system ??
jack
Old 06-11-2008, 07:09 AM
Bill Verburg
Jack
Don't know, I'd have to see it. AFAIK direct injection is the big change and one of these days they will get the wet sump right. The 2 big issues since day 1 seem to have been the wetsump RMS and IMS
Old 06-11-2008, 07:48 AM
pedsurg
pedsurg's Avatar
thanks Bill, so presumably one problem definitely solved (IMS) while the RMS issue remains unknown.
thanks again.
jack
Quick Reply: new porsche two piece crankcase
