993 Forum 1995-1998
Pcar.com 993 engine jacking block wanted
Old Feb 27, 2008 | 10:40 AM
silver7's Avatar
silver7
Default Pcar.com 993 engine jacking block wanted
Wanted please - my email is julian_weston@hotmail.com
thanks in advance!
Old Mar 9, 2008 | 06:12 AM
silver7's Avatar
silver7
bump - anyone know where you can get these or similar? pls
Old Mar 9, 2008 | 06:21 AM
David in LA's Avatar
David in LA
What are you looking for...the Autometrics jacking point?!! Those are no longer made but show up on eBay from time to time, but for the right ridiculous price I could be convinced to part with mine!
Old Mar 9, 2008 | 10:11 AM
AOW162435's Avatar
AOW162435
Seared
A hockey puck works perfect between the engine case and your floor jack. I bought a few for $1 each.
Andreas
Old Mar 9, 2008 | 10:24 AM
CarreraX's Avatar
CarreraX
Is this what you want? I have one that is basically perfect. I bought it on ebay and have never used. Im not sure if it works on a 993 or not. Anyway, I will sell it cheap if you want it.
File Type: jpg
File Type: jpg
Old Mar 9, 2008 | 11:02 AM
Mark in Baltimore's Avatar
Mark in Baltimore
swftiii is selling one, but you're fourth in line.
https://rennlist.com/forums/993-forum/415651-fs-last-of-993-tid-bits-to-go.html
Old Mar 9, 2008 | 11:27 AM
CarreraX's Avatar
CarreraX
Mark, So is it the same as the one that i have above? Also, I didnt see a spot under my 993 for the one that I have (although I just did a quick look under to see).
Old Mar 9, 2008 | 11:36 AM
Mark in Baltimore
Mark,
No, the one you have pictured is not the Autometrics tow hook/jacking block. Here is a photo of it:
File Type: jpg
Old Mar 9, 2008 | 11:38 AM
TRINITONY's Avatar
TRINITONY
Those are Rare...
Old Mar 9, 2008 | 11:40 AM
AX993's Avatar
AX993
Anybody know why Autometrics quit making them ??
Old Mar 9, 2008 | 11:52 AM
dutchcrunch's Avatar
dutchcrunch
Default jacking
jacking at the engine i know people do this but sounds risky to me, putting a lot of stess on the rear engine support hangar and engine mounts. not to mention if your jack does not roll as you are going up, or if you do not release the brakes and take it out of gear so the car can roll. the rear engine support granted supports the engine but now you are reversing that weight and not only adding the engine weight but the weight of the rear of the car too. not trying to start a long debate, just making a point.
Old Mar 9, 2008 | 11:53 AM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
These will be available soon through Robin. There is a batch of 24 made right now. We are waiting to trial fit one to a 96-98 car.
Old Mar 9, 2008 | 12:03 PM
CarreraX's Avatar
CarreraX
Gotcha! I thought it was a jacking pad that he wanted. That tow hook jacking block is cool!
Old Mar 9, 2008 | 12:16 PM
AX993's Avatar
AX993
Chris W,
Do you think there would be any ground clearance problems with these on a lowered street driven car ?
Old Mar 9, 2008 | 12:29 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
Originally Posted by glenn '88 944S
Chris W,
This is the sole reason the toe-hook boss was removed - there is evidence they touched the ground. Although, probably only on steep(er) driveways etc.
