993 Forum 1995-1998
Pcar.com 993 engine jacking block wanted
Old 03-09-2008, 06:38 PM
  #31
Mark in Baltimore
Mark in Baltimore's Avatar
Originally Posted by AOW162435
Mark,
Just tell Chris to weld your O2 sensor bung somewhere else on that center portion of the cat.....
Easy as that.
Andreas
Thank yo, AO. The position of the sensor is limited by the length of the sensor lead. Not sure how much slack I have and would prefer a piece that somehow allows room for the sensor. Additionally, since I'm not sure how I'll like the bypass and may put the cat back on, I like to plan for other contingencies.
Old 03-09-2008, 08:16 PM
  #32
Ag02M5
Ag02M5's Avatar
Need a 964 version Chris!
Old 03-09-2008, 10:06 PM
  #33
hyphenf15
hyphenf15's Avatar
I'm interested too. Put me on the list.
Old 03-09-2008, 11:15 PM
  #34
fullbooker
fullbooker's Avatar
Chris,
Count me in for one, also!
Phil
Old 03-09-2008, 11:19 PM
  #35
Nuff
Nuff's Avatar
Me, too.
Old 03-10-2008, 01:21 AM
  #36
kcirderf
kcirderf's Avatar
Hi Chris,
Put me on the list. I need one of jacking points!
Thanks, Fred
Old 03-10-2008, 07:33 AM
  #37
silver7
silver7's Avatar
I would definitely want one of these, my email is julian_weston@hotmail.com. Please put me down for one!
Old 03-10-2008, 09:56 AM
  #38
Marco8
Marco8's Avatar
I'm interested too, please add to list.
Thanks,
Marco
Old 03-10-2008, 10:10 AM
  #39
Raptor
Raptor's Avatar
Please add me to the list. Thanks.
Old 03-10-2008, 10:24 AM
  #40
AX993
AX993's Avatar
Chris , any idea on cost and ETA yet?
Old 03-10-2008, 10:33 AM
  #41
jungleboy
jungleboy's Avatar
Chris, I would be interested too... Cost?
Old 03-10-2008, 11:47 AM
  #42
flyenby
flyenby's Avatar
I am also interested thanks
Old 03-10-2008, 12:54 PM
  #43
brucec59
brucec59's Avatar
Assuming identical mounting points to the Autometrics model, I have two - make that three - concerns (the same concerns I had with the Autometrics piece).
1. The two rear bolts could potentially be over-stressed. If the area above the jacking point is not TIGHT up against the engine case when the thing is installed, a rotation will be introduced by the jack, with this piece acting as a lever, causing the two rear bolts to be pulled rearward. Yes, I see there is a bolt above the jack point, but you can't expect surface friction of one bolt head and one nut to support the entire weight of the rear of the car, to prevent rotation of the piece.
For reference, this photo is from p-car.com (http://p-car.com/diy/jacktowpoint).
1a. I hope you will be supplying a longer bolt. Photo from above link.
2. The jacking point sits under a different place from where you would normall put the jack without this piece. The case may indeed be equally strong or stronger at this point, I just don't know - it's just a different spot.
3. I'm sure this peice doesn't weigh much, but you are adding some weight to the rear of the car. Parts that don't exist weigh nothing and never break.
Old 03-13-2008, 05:04 PM
  #44
silver7
silver7's Avatar
Default any update?
on when these would be available?
thanks
Quick Reply: Pcar.com 993 engine jacking block wanted
