993 Forum 1995-1998
993 Quirks
Old 01-25-2008, 02:53 PM
Leander
Leander's Avatar
Default 993 Quirks
I know this has been done before, but it might be fun to compile a new list of all the quirks that are inherent with our cars. To get started:
Fast flashing indicator light warning of a burned-out tail-light.
Offset steering wheel.
Offset side mirrors.
In-built redundancy of valve-guides.
Over-sensitive CEL light.
Undertray.
Grinding rear spoiler mechanism.
Door check strap.
Switchblade key.
Headlight washers.
Rusting window strips.
Cassette tapes holder.
SUV ride-height.
Old 01-25-2008, 02:54 PM
FLA997
FLA997's Avatar
The NA cars are underpowered.......
Old 01-25-2008, 02:55 PM
Reuben
Reuben's Avatar
How about the obscenely large turning circle?
Old 01-25-2008, 03:00 PM
timothymoffat
timothymoffat's Avatar
Received 1,043 Likes on 470 Posts
Overly good looking!
Old 01-25-2008, 03:09 PM
pewter82
pewter82's Avatar
I disagree on the ride height, an opinion from a guy on the "outside" of 993 ownership I think the look of the stock ride height is just fine. Handling increases with the lowering ,but these were close to 1G from the factory correct?
Old 01-25-2008, 03:26 PM
dhicks
dhicks's Avatar
Window switch breakage
Overly heavy flywheel
Clearing immobilizer before starting when car has been unlocked for over 5 mins
Getting ISV on and off with engine in place
Inability to detemine oil level unless hot
Old 01-25-2008, 03:31 PM
TRINITONY
TRINITONY's Avatar
IMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM MMMMMMMMMMMMMMOBILIZER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oil gauge with a mind of its own.
Old 01-25-2008, 03:35 PM
AOW162435
Seared
AOW162435's Avatar
With practice, the turning circle can be greatly reduced. At the expense of the rear tires.
Andreas
Old 01-25-2008, 03:36 PM
NOH20
NOH20's Avatar
Rear wheels not centered over wheel well.
Old 01-25-2008, 03:38 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Rather odd depreciation curve.
Old 01-25-2008, 03:46 PM
cabrio993
cabrio993's Avatar
- Clutch and brake pedals hinged at the floor board.
- Wood floor pedal board on a $70K+ sports car.
- Mysterious kinematic rear alignment that only 3 people in the world can do with a $15K Porsche tool.
- Wipers resting on driver side obstructing beautiful view of curved fenders.
- General Motor Truck-like steering wheel.
brucec59
brucec59's Avatar
Fast flashing indicating worn out bulb - NORMAL for most cars
Offset mirrors - NORMAL for most cars
How about:
Must lean over to tune radio.
Cannot see climate controls behind steering wheel.
Old 01-25-2008, 03:48 PM
cabrio993
cabrio993's Avatar
Just a side note....rear wheels get centered correctly once the car is lowered to designed ride heights. The U.S. SUV height brings the wheel closer to the front of the wheel well.
Old 01-25-2008, 03:49 PM
993C4Smontreal
993C4Smontreal's Avatar
can this be reversed?
Old 01-25-2008, 03:51 PM
goofballdeluxe
goofballdeluxe's Avatar
Umm, is the top-end after 70K miles a quirk, a design blunder, or both?
Quick Reply: 993 Quirks
