993 Forum 1995-1998
PSS-9s vs. RoW M030
Old 05-21-2007, 05:09 PM
Harry L
Harry L's Avatar
Default PSS-9s vs. RoW M030
My 993 C4 Coupe has PSS-9s that were installed about 4 years/20k miles ago. The car is my daily driver and I am getting battered.
I want to convert to the RoW M030 (possibly with Bilstein HDs) set-up, or possibly H&R springs with HDs.
Will the RoW M030 set-up be noticeably more compliant, or roughly equivalent to my PSS-9s (at full soft)?
Old 05-21-2007, 05:13 PM
jdistefa
jdistefa's Avatar
You may want to consider the M033 springs with Bilstein HDs. Softer spring than the M030. I've never run the M030/HD combo, but several people here on the board will probably tell you that the feel is similar to PSS9s at full soft.
Old 05-21-2007, 05:15 PM
911's Avatar
Harry, your ride is still too stiff with the lowest PSS9 settings (i.e. 9)?
Old 05-21-2007, 05:33 PM
TheOtherEric
TheOtherEric's Avatar
My car had the US 030 springs (which IIRC have the same rates as ROW 030) before I installed PSS9's. Yes, the 030 springs are noticably more compliant. Most definitely.
p.s. PSS9's at full soft is not a good setting. You need to run them at 7-8. A lot of people, including me, have seen visible porpoising of our cars at 9 setting.
Old 05-21-2007, 05:47 PM
brucec59
brucec59's Avatar
I can't compare directly w/ PSS9, but my ROW M030 w/ Bilstiens is pretty stiff over rough roads. The only time I really notice it, tho, is when I have a passenger. It doesn't bother me most of the time. It's my daily driver, too.
Old 05-21-2007, 06:25 PM
Jack of Hearts
Jack of Hearts's Avatar
what tire pressures are you running? at the factory recc. tire pressures any sport suspension has a VERY rough ride over potholed roads.
Old 05-21-2007, 07:30 PM
Land Jet
Land Jet's Avatar
If H&R springs are anything like the H&R coilovers on my car, you better have the fillings in your teeth tightened up. They are great on the track but not real nice on the street. I will probably go to PSS9's so I can have a softer street ride, and the ability to dial in firmness at the track. LOL.
Old 05-21-2007, 07:57 PM
Wilder
Wilder's Avatar
Received 5,105 Likes on 1,814 Posts
I agree with the M033 option. I have access to a turbo with PSS9s set up at 8ish for street and I find it a tad softer than my HD/M030 setup.
Old 05-21-2007, 10:33 PM
TroyN
TroyN's Avatar
I had RoW M030 (springs and struts/shocks) before my PSS9s and they were stiffer than the PSS9s at full soft. Maybe like 7, or between 7 and 6, two+ clicks from full soft.
Old 05-21-2007, 10:40 PM
rconnon
rconnon's Avatar
I have PSS9's and run 5 in the city and dont find it bad. vancouver has some pretty bad roads as well..but to each his own.. i personally found '9' felt like the car was floating on a cloud.
Old 05-21-2007, 11:42 PM
Randy 1
Randy 1's Avatar
Originally Posted by rconnon
vancouver has some pretty bad roads as well...
Um...no.
Vancouver has the equivalent of fine Chinese rugs for asphalt in comparison to LA or Houston. The streets around where I hang my hat in LA are a gnarled mess of cut-and-cover scars from sewer work that sometimes exceeds and an inch and a half in depth (!!!!!). I'm tempted to check to see if my wheels are cracked every time I come home. Not good times.
I'm fixin' to slap the PSS-9s on as well. My hope is they're a little (re: a lot) more forgiving than my alternatives.
Old 05-21-2007, 11:56 PM
CarmG993
CarmG993's Avatar
I have the M030 setup and it is pretty rough ride. I did have H&R springs on my 95 (stiff, but slammed look) and the M030 is a much harsher ride. Can't comment on the PSS9's.
Old 05-22-2007, 01:45 AM
Pete Lech
Lifetime Member
Pete Lech's Avatar
I have the US M030s with 9 & 11 X 18 inch wheels = harsh ride. Recently drove a narrow body 993 with H & Rs, and the ride was a lot more compliant. Perhaps the wheels have a lot to do with it.
Old 05-22-2007, 02:38 AM
Peter R.
Peter R.'s Avatar
I find my factory M030 setup tough as nails. It goes like a go cart around bends, but on cobbles, oh boy !
Peter R.
Old 05-22-2007, 11:06 AM
RallyJon
Weathergirl
RallyJon's Avatar
I've been very happy with the ride of US M030 springs and Bilstein HDs. Decently controlled and very comfy. I am running a fairly light 17" wheel/tire combo though. With Yoko or Bridgerock 18s, it might be a lot crashier.
Quick Reply: PSS-9s vs. RoW M030
