Aftermarket HIDs
#211
Got mine from DDM. Great product ie plug n play, but CS leaves a lot to be desired. Getting a live person on the phone can be a real trial of perseverance and patience. Overall I would buy this kit again.
#212
Very impressive brightness, and illumination, pure bright white
Both kits delivered(with slim ballasts)were about $91 to my door, standard H1, and H3 kits.
#213
I have purchased 3 sets over the years, all off eBay. the original ones I got were about $120, then the continued to go down. I think I paid somewhere in the area of $50 for my last set in 2009, that I have in our Sienna.
I have not had any problems with any of the ballasts or bulbs since I installed them.
Many have had good success as noted with the DDM units. I believe Vertex also carries HIDS kits.
#214
My DDM kit is pretty new and I like it. Inexpensive an an easy install with a DIY on this forum.
Through reading this thread though seems like the light color may vary by brand a bit. The 5000 DDM's are very white with almost no hint of blue. Reads like the 5000's in other brands could be much more blue.
#215
#216
Dremel, clean up, etc? Is that just on the DDM? I have a Vertex kit on my cab which was pretty easy and didn't require any such drilling/filing/dremeling. I was just seeing if there was anything newer/better.
#217
I have DDM HIDs, and didn't have to drill/dremel anything. The bulbs fit just fine.
#218
Ok, so finally after almost 2 years one of my DDM HID ballast went kaput! Both bulbs are still good. Not bad considering I only spent $45. Now I'm thinking about stepping up to the Morimoto kit. I have this in my DD Toyota, and it is a very impressive kit. Fit and finish are excellent.
#219
ake a look at my earlier posting.
Search under "Installing HID headlights on 993 - The Gotchas "
Andy :-)
Andy :-)
#222
The T-Light kit has of course the correct connectors for hassle-free installation as well as the possibility of using the halogen bulb as quick-fix spare.
Cheers,
Tore
Cheers,
Tore
