Aftermarket HIDs
#166
I just installed mine last night. I went with the set recommended by CarreraX (referenced above) I got the 5000K...seems to look fine, with a hint of blue (reminds me of BMW xenons). The install was easy, and consider that I am an electrical retard. I printed the photos from this thread and it was a snap. I used all bullet type connectors so it can be reversed (if these turn out to be unreliable). I did not have to use a dremel or mod the housing in any way. I wrestled with the bulb retaining spring for a few minutes, but wedged it in there pretty good. I have the larger ballasts...it was a tight fit, but it all worked out.
Thanks!
Doug
Thanks!
Doug
#167
Thanks all!
I wil need to work our shipping / import tax to see which is best - US or UK.
Andy - were you able to fit the aceparts ballasts inside the headlamps / how much modding was needed?
Tim
Tim
#168
2nd Gear
Hi Tim
No mods necessary. It's a tight fit to get the ballast and wiring in the bucket so a little patience is required.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
You'll need a "bullet" connector, or similar for each side. See post # 57 on this thread.
Take your time; get the correct connector and tools and you'll be able to do this easily.
The guy at Ace Parts (Guernsey, UK) owns a 993TT and knows his onions.
(No affiliation)
I'd suggest that for an extra £10 you opt for the upgraded sidelights. I haven't fitted them yet but the car looks very odd with the OEM sidelights
Andy
(No affiliation)
Andy
#169
Sorry to bring this thread back to life but I have a question about the filing of the opening for the HID bulb.
I'm finally at the point of installing the HID kit (DistantXtremes) and I just wonder how you guys that had to file the opening manage to keep the filings out of the projector beam reflector? I can stuff it with some cloth but I don't want to loose it in there. What did you guys do?
Thanks,
Hans
Thanks,
Hans
#170
I held the headlight upside down (lense up) and let the filings drop down on the floor and away from the headlight. It was a bit of a pain, but there isn't that much filing to do, so it is manageable.
#172
Hmmm - I just paid Vertex 229 for mine. Supposedly will come already made with hardware that has been modded to fit the 993. Did I get ripped??!?!?!
#174
Put it this way. I bought the Pilot HD kit from pilothid.com for 189 and I got also purchased their 5 year warranty that includes bulb replacement for a total of 265. Did you get ripped off? Only you can say.
#175
Hans - I held mine upside down, the vacuum technique sounds like it might work too. Great upgrade.
#176
Thanks,
Hans
Thanks,
Hans
Good luck...
-Chris
#177
I had to file mine (XenonWorks kit). I just layed on my back with safety goggles and held it up so it would all fall out towards me. You shouldn't need to file that much out. I was REALLY nervous about doing it until I got in and did it and realized it was pretty straight forward and easy to do.
#178
R.I.P
It's still alive. I used the Dremel. One of those sandpaper like drums was the perfect size for the job. Done in a second, no sweat. I don't know how I managed to live for so many years without a Dremel.
#179
Great feedback guys!
I'll be trying all as mentioned - I have the dremel tool with the drum sander - on my back - goggles and holding the vacuum with my teeth..........![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
#180
POACB
So I have my slim ballast kit and plan on installing this weekend. Am I right in understanding that the brown ground wire no longer needs to be connected the the metal headlight housing and is ok just being attached to the new ballast via a bullet connector?
