Bubblicious
so lets see how things went.
first, good news is that i've now memorized that black=negative and red=positive on the batteries and cabling. taking out a battery, neg positive. putting it in, connect in order of positive negative. my memory game was like "coming out is negative so negative positive. " going in means good thingsa re to happen, so Positive negative. really, thats how my brain works.
used a recommendation and hooked up a charger to the battery leads since the battery was removed. got seinfeld up in one crank, moved it to the warehosue door, backed it righ tup, opened door to just enough over exhaust and ran it for 25 minutes.
now bubble artic i had to put the battery back in since i had only 1 charger. the cars are lined up in pairs as you'll see in photos so i only have to move 1 car worst to get to any 1 of them. ran grey boy for 20 minutes. air conditioner kicking for 5minutes a the end. a little wipe and clean while running and back they went.
pushed the envelope a bit and moved them over to the mohawk. had to abandon. seems like the clearance is super tight. the mohawk with the arm that pops up is a very low clearance but just doesnt clear that skirt. protosport uses hockey pucks. literally hockey pucks on those pads to make contact. so that also wouldnt clear though i could have popped it on udnerneat. a quick call to protosport (love that they take my call when i call right away...) and paul gives me some tips. he starts saying i could remove that skirt, or...and i abandon. they'll be here next week and i'll watch. learn instead of F'ing up with the one of a kind seinfeld. see i'm not that foolish.
got them back in bubbles. takes about 2 minutes to get the bubble on. key is to roll up the plaster cover. heavy and you dont wan tto be pulling that across the finish. unroll in chucks. also lets it come on/off evenly that way.
locked the doors. went back the office. very nice lunch break.
94 turbo S comes tommorrow. white. im so excited i might not sleep tonight. unfortunately the red jordan never had a chance to carve a spot in my heart. take care sweet chariot.
the 94 turbo, seinfeld and article 634 miler (alias, bubble car) i was going to try to do the most min # of miles. a few of the others, like all of us, i want to drive but again, a sliding scale...nicer=less miles. fyi, the 96 turbo is the "driver". 6k miles and i plan on, and have already, driven it a bit. really nice.
idle...u think thats a problem? a few suggested it, but ensuring i run A/c and heat during that period. i push throttle a few tmies to TRY<try?> to burn off any water in exhaust.
and of course, it gets rolled a bit for the tires.
thoughts, idea...come one come all...
funny, we had the "maintaining super low mileage "t hread. someone recommened "new thread" and this topic seems rigth back there.
how about the hockey puck for the lifting points as a recommendationb y Protosport. thats a neat trick. vulvanized rubber that compresses just that wee bit.
Maybe you could buy a dyno if you're afraid of getting them dirty. It seems a real shame to not let these beasts run free every so often.
As an alternative, have you considered something like a four wheel chassis dynometer? All the measuring devices are unnecessary - just the load wheels/rollers to allow the drive train and engine to perform under a modest load.
dyno. dyno. dyno... (for allwheel drive btw)
( but first, 'bout some pics steve? ) you're killin' us...
later.
I'm a simpleton.
