Pro/Con for sunroof delete
I did the search and came up empty.... I would like to hear the good v.s. bad if, any, if I were to replace the roof of my car (see 'My Sad, sad, Fraiday') with a new factory roof with no sunroof. My primary thought was to lower repair costs with a side benifit of cleaner lines. In the couple of years that I have owned the car, I may have opened the sunroof twice. I would think the delete would result in a slightly stiffer car? Someone said no, and that additional stiffeners would need to be added. I do not know if the stock 'delete' roof is any different from the one with a big hole in it.
Any input is most welcomed!!!
Thanks!!!!!!
Thanks!!!!!!
I would do it just for the headroom, as I always did when sunroofs were optional. If you don't need the room, i would put it back the way it was and keep the car "original".
Personally I wouldn't want a car without a sunroof...actually I would love to have a cab, but I just can't handle to loss of the "roofline" that comes with a 911 cab. I would think this is a VERY individual preference though. I mean if you never use it, I would not get it. I use mine EVERYTIME I drive my car.
BTW, the sunroof does take up a lot headroom...during the few DEs that I have done, I have to lean down slightly because my helmet hits the roof...and I'm only 5'10".
pros:
1) lighter
2) more headroom (noticable on the track especially)
3) one less thing to break
4) cleaner lines
5) easier to wax![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
cons:
1) that one time per year you would actually use the sunroof
1) lighter
4) cleaner lines
5) easier to wax
cons:
I rarely use mine and even if I didn't need the extra head room I would look at it as an opportunity to get rid of it...they all leak at some point and have parts that break. You say you never use it anyway so why would you want it back?
c
c
Granted my 993 is not my daily driver but I am surprised to hear you guys say what you do.
I do not back my car out of the garage until both windows and sunroof are wide open. It's one of the things I love about the 993.
- Of course it's closed at the track but I've never had a headroom problem even with my helmet on and I'm 5'11.
I would never buy a coupe car without a sunroof (unless it was a purpose built track vehicle.) as I use the sunroof all the time. It would be a deal breaker.
B
B
I replaced the sunroof with a non sunroof skin on my racecar. I think there was about 40lbs of weight savings and additional headroom was gained. Not a real big issue to change out. I don't think there is a difference in strength, in fact, the sunroof roofs may be stronger due to the additional metal.
I agree with mborkow...original is gone (yes, you can put the stock parts back on, I know) and the fact that the roof has been replaced will probably kill the resale value - sunroof or not.
When you get ready to sell it, the track guys are going to like the sunroof delete. You may even turn it into a track car at some point.
You asked...;-) Good luck with the repairs!!!
Morgan
Morgan
Ditto what jackb911 said.
I really regret buying my RSA w/ a sunroof, but didn't know better at the time. It is down on the list to replace, but it is on the list. I think it will be around $2,500-$3k including labor. Maybe on the low side if you get a used roof instead of buying new. I have read several times the headliner is a bitch to replace and is probably a decent chunk of that $.
Originally Posted by mborkow
mr_bock doesn't have a choice (since his was crushed), but don't you think you will hurt your resale value if you replace the roof?
http://www.rsamerica.net/market/vehicles/index.htm
My plan is to keep it forever so hopefully resale won't be an issue anyway. Being 6'2" I really need the headroom w/ my helmet on and when I put in a full cage I will need the weight savings.
