Creaking normal when to body flexes/torques over driveways??
#33
#34
I had a 77 targa that creaked when the suspension was incorrect and I hope that this is the case with the 993. MY low miles C2S creaks a little in front, but I know that one of my monroes in front is leaking and when I get around to it I would like to check tlhe four corner balance. I'm too poor currently to do the suspension experience. I had a 964 that never creaked and I hope that porsche didn't economise on the frame.
#35
My windshield creaks, but I've gotten used to it enough that I don't notice most of the time.
Can anyone here advise on how/where to get a "proper" windshield installation that would remedy this? I'd be glad to get some new glass for visibility, especially if in doing so I got rid of the creaks too.
#36
Every 911 I have ever owned has creak a bit but while driving at speed we normally don't hear it over the road & exhaust noise.
My 993 flexed and popped the lower left winshield seal during some very spirited driving so I put in a titanium strut bar, now it only creaks at the rear sway bars but the windshield still leaks at the left corner in the rain, guess I should have it resealed, but then again we don't get that much rain here.
ZP44
ZP44
#37
Effectively all the creaks, groans, graunches, etc were exorcised from my car after visiting every bolt in subframes, crossmembers, and mounts with a torque wrench.
The lower right windshield squeek comes and goes .... and is a friendly reminder that this is a 993.
#38
Why do I feel so left out!
I have a solution for all of you creakers....
Mine used to creak - A welded in cage fixed it right up!!!
Simon.
Simon.
#39
I only get one noise from mine. A slight creak that sounds like it is coming from the top of the driver's side window or maybe the windshield when at speed on bumpy highways. It is a very hard sound to trace, I thought it was coming from the light assembly above the driver's door for the longest time.
#40
I had a creaking front windshield after moving back to Florida. I purchased some grey tubular foam from Home Depot (reference other write ups on Rennlist) and installed it around the front window. Cut out at least 90% of the creaks and groans from the windshield. I wish I could say my KLA strut brace fixed it, but I can't. However, the brace did wonders for the steering feel and it was fun to purchase and install.
Now if only I could figure out that squeak from the rear deck with the windows down? Any ideas out there?
#41
I have heard that Porsche used to use a lubricated rope around the front windshield, but redesigned
the window installation process to eliminate the rope for the 1995 model and on. Perhaps the rope
reduced the creaking sound.
#43
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I get max torsion on my car when I enter a driveway at an angle -- I know this because the inside front wheel is off the ground
#44
<<As many of us know, a properly installed windshield can make all the difference.>>
Not so much, in my case. I had the windshield replaced about a year ago AT THE FACTORY. After being not so politely reprimanded by the service manager for having Pedro's in there, I was given the privilege of paying roughly DOUBLE the normal price for a strip and repaint of the whole windshield frame area. (Plus side at least was that they took care of all of the surface rust under there, so I don't have to worry about that for a while.) They used the latest and greatest parts and techniques, yet the windshield STILL creaks.
I just ignore it now. Just part of the experience.
#45
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
[QUOTE=Avenger6;4695252They used the latest and greatest parts and techniques, yet the windshield STILL creaks.
I just ignore it now. Just part of the experience.[/QUOTE]
Peel back the outer seal and have a look for this grey foam cord. If its not present, get some and stuff it in there. You'll be amazed!
