Remote not working
Car was working yesterday, parked in the driveway several hours. Go to start and dash lights up but no cranking. Tried the remote and nothing happens. So walk to the grocery store a block away and get a new remote battery. Install and also replaced battery on IMMO block , again nothing, Remote battery has 12.59 v when checked. Remote light illuminates when pressed. Tried locking and then unlocking with key in door, open door, alarm sounds. Nothing again with remote fob. Quickly remove the ground off the battery. Today put the ground back on the battery , immediately goes into alarm mode, remote does nothing.
Hi Half German,
Before digging deep and spending good money try:
Check the car battery and see if it is over 12.5 volts. If not it needs a charge.
If the starter turns over the engine but it won't start and run replace the Motronic DME relay, sometimes called the fuel pump relay. The relay can also be pride open to inspect an resolder any broken connections internal to it.
If it simply won't engage the starter and rotate the engine clean the battery connections and inspect the ones at the starter.
Andy
Andy
Basic Sponsor
Read here; https://rennlist.com/forums/993-foru...ing-issue.html
And here; https://rennlist.com/forums/993-foru...arm-issue.html
Loren
Systems Consulting - Automotive Electronics
Specializing in Porsche cars
http://www.systemsc.com/
Loren
![](https://rennlist.com/forums/signaturepics/sigpic266260_7.gif)
I agree with Loren. I have fixed many of the Porsche 993 key fobs. The switch fails, as well as component solderings. Some even develop internal corrosion due to moisture or battery leaks.
Cheers,
Tore
Cheers,
Tore
Basic Sponsor
Thanks for the replies. Looks like I have to pull the seat to get at the immobilizer. Ordered the proper hex tools for the seat bolts, found in this thread: https://rennlist.com/forums/993-foru...eat-bolts.html
Hopefully I have them by this weekend so I can work on the car. Will keep everyone updated.
Harold
Harold
Got the seat out, someone's definitely been in there before me. One bolt was a regular allen head the other 5 stock. Some worse than others, enough that I do not want to reuse. Ordered a replacement set ( replica's) from Sierra Madre. Will see what head they use, could not tell from their stock pic. No security cover over the CPU , module.
Will send remote / module to a fellow Rennlister to check out for me. At the very least getting the caps replaced on the immobilizer.
jay@EZimmoblock.com (04-15-2023)
Basic Sponsor
I have a problem too, i have a 95 c2 cab, i cannot program the remote since the immbo light didn;t turn on the clock at all. I put the new leds on the clock, still not working. Clean the contacts to the clock and still unable to program it. I saw the ecu doctors about programming remote video, but when i close the door wait couple seconds (see the alarm led light flashing slowly), lock and unlock, i didn't hear the horn beep. But I am sure i have immobilizer, since i got the code from dealer. 2nd i have led flashing when i use the key to lock the door at the driver side. 3rd, when i lock the door waited for 5mins and unlock the vehicle from inside, alarms will goes off. Anyone have any ideas? Thanks
Basic Sponsor
or replacing the ignition switch. We have provided the external programming service to many Porsche independents and dealers.
Basic Sponsor
2) If the door LED double flashes when you lock the door, one or more of the following is open: either door, the frunk, the engine lid, or the glovebox. Or the radio is out. The cab may have other switches that are monitored. (If the door LED single flashes. that's normal),
3) Once you lock the door, the only way to open it without sounding the alarm is with the FOB. Even the inside door handle will trip the alarm.
Basic Sponsor
Once the immobilizer is functioning properly AND you have fully functional original (20+ yrs) OEM FOBs, the range is typically 20+ feet.
