FYI-
For those that anticipate installing the plug-and-play IMMO BLOCK - the took kit below is highly recommended for removing the fuel gauge. I did mine a while back with a putty knife, but these tools work the angles better and are less likely to mar the surface. Harbor Freight sells the kit for less than $10.
FYI-
I bought what appears to be the exact same set but in black nylon rather than yellow at Walmart for ~$6 iirc
Still shooting for 1st week in Mar. I'll be able to confirm that after first articles arrive and are verified "good". That's supposed to happen end of this week. Final assembly, programming, test will be done in house which should go smoothly. At that point I'll be PM'ing people on the list with purchasing information. So if you're not on the list and want to be, PM or post ASAP and I'll add you. Thanks.
Current list:
1963SWC
2000VRM66
71-3.0-911
911Boss
993Auto
Academictech
airkuhl993
Alan Smithee
AZ993
beekay
Ben5001
Boxster-pte
Brig993
C Ward
CarreraX
Der ABT
DES993
djwpe
dmdinh
drodg
Dutch NY
ezinternet
F18drvr
FatMike
flashdavy
FlyingDutchman
gavonder
GC96
Gmanscott
gonzilla
GregSC
imdvs
J.O.
JB 911
Jon 'Bama
JPS
jupiterfish
jwex16
Kein_Ersatz
KeninBlaine
levtron
LimeyBoy
LJ993
Madturk
Magicscott
Mark FM
marknkidz
marquez
MBR993
MDA0303
mhm993
Mike J
Mr.Woolery
Musche
NC TRACKRAT
Neuro
Onami
onelove
orangebox
Paseb
Paul M
ptam
puako
rcb912
rcg412
red67vert
rg0115
rk-d
rs911porsche
rsa964
Seamless
ShdwFx
SpeedyC2
TheFatArmadillo
tikka308
Todynot
TxnBluDvl
