993 Forum 1995-1998
Building a 993 Supercharged RSR clone
Old 08-24-2021, 06:35 PM
  #106
Meenrod
Meenrod's Avatar
And finally, I am also having Patrick fit an RSR fender flare kit. I already have the RS Clubsport aero package so this is something I've always wanted to do.
Ready to start the RSR conversion... no going back now.
Old 08-24-2021, 08:39 PM
  #107
Meenrod
Meenrod's Avatar
No coming back at this point
Old 08-25-2021, 02:56 AM
  #108
kevie_p
kevie_p's Avatar
OMG.... sick looking. I''m a bit bias since I'm building an black RSR look a like myself.
What kind of wheel setup are you putting on the car? I'm waiting on silver e88s
Old 08-25-2021, 09:16 AM
  #109
JEllis
JEllis's Avatar
Wow!
Old 08-25-2021, 10:08 AM
  #110
wagongotya
wagongotya's Avatar
HOT
Old 08-25-2021, 11:38 AM
  #111
MarinS4
MarinS4's Avatar
Props for ambitions to create your vision of the ultimate 993!
I was great to see you step up and properly tune the TPC now this. I have similar plans for the trans, I only want to change 1st and 2nd. Didn't know they could machine and weld on new gears. That would certainly open up some options. If I go down a similar path I would use the 97 input shaft as a basis though. The 96 is know to warp under high power hence the revision in 97.
While I am sorry for your engine woes it does seem like another opportunity to upgrade. You'll be shocked what cams can do for you at this stage. I used the DC21 on a 116 LSA to create a REALLY broad flat torque curve. Something similar to that would work well for you too.
I am sitting on some ECU's so if you're tempted by Motec, Syvecs or Emtron let me know, I'll hook you up.
Old 08-25-2021, 01:31 PM
  #112
Meenrod
Meenrod's Avatar
Thanks - the 97 input shaft is interesting- I'll look into it. I met with Patrick last night and discussed the options. The only slight issue is that aftermarket gears are noisy(er) and they are recommending I may want to use Porsche gears for 1 and 2 which would nesecitate a main shaft. Euro RS 1st is available. Since my 3rd is damaged I may end up replacing 1 through 3. Any thoughts?
Interested in the Motec- send me a PM! Cheers.
Old 08-25-2021, 01:37 PM
  #113
Meenrod
Meenrod's Avatar
Thanks. I'm having my RS Speedlines rebuilt and widened by @jim dorociak to 9" front and 11.5" rear. He does amazing work. Photos to follow.
Old 09-05-2021, 08:50 AM
  #114
Meenrod
Meenrod's Avatar
They started on the engine build and as suspected there was some signs of wear, not much, but enough to warrant the tear down. Of more concern was the scorch marks on the heads and cylinders indicating some blow by so that will all be addressed. Taking the opportunity to enlarge to 3.8 and looking into some custom cams to really take advantage of the low down torque available from the supercharger. More to come.
Old 09-05-2021, 08:53 AM
  #115
Meenrod
Meenrod's Avatar
Meanwhile things are progressing well in the bodyshop. They are using threaded inserts to ensure the fender and quarter extensions are properly mounted to the body. Very nice attention to detail.
Old 09-06-2021, 10:04 PM
  #116
mike5876
mike5876's Avatar
Default turbo
love to see how your car with the blower feels compared to my c2s with the proto tech twin set up
kos11-12 (09-24-2021)
Old 09-06-2021, 10:27 PM
  #117
Meenrod
Meenrod's Avatar
Supercool! Probably quite different - mine is all low down torque changing at max 5500 or 5700 revs. I've never driven a turbo 911 to compare.
Old 09-07-2021, 12:28 AM
  #118
MarinS4
MarinS4's Avatar
My twin! John does amazing work!!! I have a built engine with GT2860's on mine. It's making 600hp at 10psi on 100oct.
Old 09-07-2021, 12:38 AM
  #119
JEllis
JEllis's Avatar
Loving this thread!
Meenrod (09-07-2021)
Old 09-07-2021, 02:20 AM
  #120
MarinS4
MarinS4's Avatar
Originally Posted by JEllis
Loving this thread!
I look forward to seeing the results of a well built 3.8 with cams. I've always loved how perky the TPC cars were and now meenrod is taking it to a whole new level.
Quick Reply: Building a 993 Supercharged RSR clone
