Tracktool upgrade, sunroof and rain gutter delete and others …
#122
Re rear windows; if you refer to the makrolon windows, they are from https://www.plastics4performance.com...ts/porsche/993
#123
Hi at present I have a 993 5 speed box with a CAE shifter,this is great,would I still be able to use this or is it cables not a rod?
Difficult to find a 993 6 speed so a 996/997 gt3 box a lot easier to find.
Do you have any pics you can share of installation.
Did you also regear the 996 gt3 box?
Thx for info
Thx for info
#124
Thx for info
Thx for info
As said installation was pretty much straight forward. You need a custom made main bracket for both possible kinds of installation, the cables and a cable shifter. Rest is common work.
shortened housing and shaft
starter spacer
Installed
Will ask my friend if he has pictures from the needed chassis cut out on his swapp
#125
Here we go ...
He kept the cables in the tunnel and uses a Numeric shifter.
On my car the cables getting out of the tunnel towards the CAE shifter. The 996/7 CAE does not fit into the tunnel!
kos11-12 (07-29-2023)
#126
Hi great info
Will any 996/997 box work or does it have to be a GT3?
This could work would need a new CAE shifter as already have that could then sell the 993 box and CAE shifter.
Do you have specs of the mounting bracket looks great.
Here's my cae shifter
Was planning on handbrake delete to remote switch so cables will work OK
Did you also go for a 4l engine
#127
It has to be a GT2/3 or turbo gearbox, they were the only 996/7 still using the 'Metzger' housing.
As you can see, no real need to delete the handbrake. And here the would not register it anymore without original handbrake.
maybe check this thread from the beginning, it might answer a lot of further questions )
Yes, its a 4.0L
btw. your car looks pretty good already, good luck on further improvements
Yes, its a 4.0L
Holger3.2 (07-28-2023)
993Porsche (07-29-2023)
#131
#133
Holger3.2 (09-25-2023)
