Anyone running a wide set up - 9s and 12s?
Looking for fitment possibilities or issues with 9” up front and/or 12” in the back. I have offsets i’m thinking about, but i’m curious if anyone has had trouble or success at those widths on a 993 WB.
thanks!
thanks!
On a stock C4S, the widest that I have run in the front is 18x9 ET52 and 245/35-18 tires no issues. The widest in the rear that I have run is 11" with an ET of 45 and a 295/30-18 tire with no issues. Are you planning on running 305 tires in the rear with a 12" wheel?
now my mechanic says don’t mess with the OEM set up on the C4S due to the AWD system. What size tires F and R are you running?
just keep tyre OD within 3% front / back.
or
remove the fastener that connects the front drive tube to the transmission. (that's the cheapest / easiest way to convert to RWD, though certainly not the best.
Have fun.
Originally Posted by rsabeebe
with et40 in the rear, are you running a spacer or is that a direct fit?
thanks.
thanks.
Andy
