Tramont Cup 2 Group Buy
#511
For anyone considering purchasing from Tramont - be aware that their damage policy requires the recipient to inspect the wheels IN THE PRESENCE OF THE DHL DELIVERY GUY. All four of my barrels have runout that is outside of acceptable specs. Two of the four lips are also bent out of spec. Barrels could theoretically be repaired, but lips need to be replaced since the repair process would damage the anodized finish on the lips.
#513
#514
Got them today. 3" outer on the rear and 1.5" front. After all the stories, I inspected them very carefully. 1 wheel has a very slight imperfection on the outer barrel but it does not look like a drop damage and at least visually I can't see a flat spot. But I guess you only really know once they are on the wheel machine. I will mount them asap as soon as I get the tires.
Anyway, I have to say I am impressed with their delivery time, took 1 week (to Europe) and they do look great...
#515
#516
I placed an order through Darin at FD, I plan to take the day off when they are due to arrive. Visual inspection can seem like they are fine, but it is not until they are on wheel balancing machine that will rule if the wheels are straight. I plan to do this right away myself. I will email Christine what their policy is on this as filing a claim with DHL is not something that makes me feel comfortable as they can just deny it.
I hope mine arrive undamaged, but I am getting a bit concerned hearing these stories from different folks here. The way I see it, if the customer discovers they are damaged when you take them to the wheel shop, it is on Tramont to correct it as visual inspection may not indicate this. DHL or any carrier will only take responsibility if the boxes are obviously damage when you take delivery of the wheels, and they can always just blame it on the shipper not properly packaging the wheels.
#517
what size and offset did you go with?
It's for a widebody: 8.5" ET49 (1.5" outer), 11" ET44 (3" outer). I went with a relatively mild fitment to make sure I'm not limited in tire selection, it's about 3-4mm more ET than the WB recommendation. I'm going to order Michelin PS4S 295/30 and most probably 235/40.
225/40 and 295/30 was standard on 996tt's and that would actually be an almost perfect height match front/rear (I have all wheel drive), so that would be an option too.
Astro_Train (04-01-2023)
#518
I'm also quite concerned now...
I emailed Christine and explained my concern based on what’s happened to folks that aren’t in Europe. I don’t want anyone (myself included of course) to end up with damaged wheels without them at least fixing the issue with us the customers.
I’ll post once I hear back from her.
#519
Anyone know if Tramont has a 17" front fitment that clears big reds? Would a 17x8.5 et 50ish put the wheel center flange & bolts sufficiently away from the calipers to work?
#523
I received my wheels today. Ordered them march 16. That was pretty fast.
DHL just left them on my door step. So much for “inspecting them in the presence of the delivery driver”. I took them to my local shop. Will have them placed on tire machine tomorrow to ensure they are good to go. They are definitely pretty.
3point2 (04-03-2023)
#524
A couple of things. My wheels are thankfully in very good shape after the shop looked at them. See video attached of the one that had a very minor imperfection but the shop told me it will not effect the performance of the wheel nor the way the car drives.
So I spoke to Christine and she said damage in shipping is rare but basically if it happens then we have to go through DHL and file a claim. That did not make me feel too good. Although I’m very relieved that mine were not damaged. Or I’d be pretty pissed if I had to deal with DHL.
I will say that I have purchased many sets of wheels in the past and Tramont’s packaging can improve. The company I compare them to is Rays and BBS Japan. I’ve bought at least half of dozen Volks and 3 sets of BBSs in the past.
I will post pics of the wheels once I get them mounted.
A pic of the rear lip. These are 3” versions, have not seen any NB with them yet.
#525
Astro_Train (04-05-2023)
