MEngineering vs. Softronic Tune
Old Jul 20, 2024 | 12:17 AM
  #106
jlegelis's Avatar
jlegelis
Originally Posted by BarryC
Sure if I own the car that long. I was commenting about the injectors not the original tune since someone on this board speculated that the injectors were likely in the process of failing.
Yep - that was me. Still standing by that statement, though since you are on the 'lesser' Softronic tune you may never know. Whatever... enjoy.
Old Jul 20, 2024 | 12:36 AM
  #107
BarryC's Avatar
BarryC
lesser? In what way and what is the basis for this comment?
Old Jul 20, 2024 | 12:07 PM
  #108
adrianp89's Avatar
adrianp89
Curious why you think the Softronic tune is “lesser”? What’s draws that conclusion?
Old Jul 20, 2024 | 04:47 PM
  #109
jlegelis's Avatar
jlegelis
I make that statement based on M-Engineering's very detailed response above, which infers the Softronic tune is making 'less' power due to the tuning technique Softronic is using (commanded mode rather than enriched lambda targets), etc. I also feel the car has a latent injector issue that will manifest in time, perhaps not 500 or even a thousand miles, but 'eventually'. The good news is the Softronic tune works for your car, so drive and enjoy.
Regards
Old Jul 20, 2024 | 05:15 PM
  #110
5thgear's Avatar
5thgear
5th Gear
I read through the thread, i would have suspected something with the new turbos myself.,
but i was satisfied with the answers from both M engineering and flat 6 so i purchased an M engineering tune and cat bypass today from flat 6. Seems like they handled the situation well.
Old Jul 20, 2024 | 06:13 PM
  #111
Softronic's Avatar
Softronic
Premium Sponsor
Veteran: Marine Corps
My hypothesis: The OP has marginal or failing injectors, and the more aggressive ME 'high lambda' map is merely exacerbating that condition causing misfires. If I were a gambling man I'd bet the injectors may begin to 'act up' over time as they age, and even the Softronic tune might not be safe. YMMV.
There is nothing special or different in the tuned lamda table posted and is typical of what a Porsche turbo would use tuned even dating back to a 996TT. I will say its actually a bit leaner than what I have used for decades ...So by those standards my tune should make the problem even worse yet it didn't. In any case that would not cause any different stress on the injector and is irrelevant.
The stock lamda as posted for this model in discussion is used in the 992T, S , GTS and the TTS. So a 3.0T ,3.0S , 3.0GTS or 3.8TTS use the same lamda target of 1.0 stock.
Now as far as the Injectors the issues as described in the TSB are from electrical problems in which "BARRYC" didn't have and is basically an open circuit. The fault codes for them had not been generated either. This is why the harness is requested with the injectors and asked not to be tampered with to check the full continuity with the injector attached when returned to PCNA. The fault codes are for a circuit issue so there wouldn't be failing injectors as mentioned from lambda settings. He was experiencing misfires which can cause damage to the cats, just to clarify. Im sure many exhaust manufacturers that sell cats can understand that and applies to stock cats as well.
I didn't think I would have to chime in on this and that someone would have noticed these items yet I was mistaken. Ive been building race engines and tuning them for more than 40 years. Even the first chips in 1983... There comes a point when you write something down people forget about it a week later and takes more time to explain it all over again. I would say the hypothesis can now be proven incorrect.
Best,
Scott
Softronic - Porsche Performance Software Tuning
Faster than a speeding bullet.
Cayman | Boxster | 911 | Cayenne
Many 24HRS Daytona Winners programmed by Softronic! along with 1 lap of America and more.
Porsche Interseries programmed along with teamed owned Tudor ,World Challenge , PCA, IMSA and others in an exclusive with Softronic.
Porsche PCA racing binary check by Softronic for compliance.
Old Jul 20, 2024 | 06:29 PM
  #112
BarryC's Avatar
BarryC
Btw, the tech at my dealer said the same about the TSB. Thus my belief my issue was not the injectors.
Old Jul 20, 2024 | 10:52 PM
  #113
jlegelis's Avatar
jlegelis
Cool. Please report back in another 10k miles.
Old Dec 7, 2025 | 10:27 PM
  #114
HKG997's Avatar
HKG997
Any update on this after 1 year?
Old Dec 7, 2025 | 10:44 PM
  #115
BarryC's Avatar
BarryC
All good here. Car is running great and is making 538hp/485 ft lbs at the wheels. Have not had a misfire or CEL since switching to the softonic tune.
Old Dec 7, 2025 | 10:52 PM
  #116
M3Inline6's Avatar
M3Inline6
Good stuff! Loving my Softronic tune as well.
Old Dec 7, 2025 | 10:55 PM
  #117
HKG997's Avatar
HKG997
Another question, what makes you choose the europipe cat?
Old Dec 8, 2025 | 06:40 AM
  #118
BarryC's Avatar
BarryC
Initially price. Once I ordered and received the cat, I've been very impressed by the customer service, build quality and performance. IMO, the europipe cats are the best solution for a high flow cat for the 992. thx bc
