My DIY 992 PTS, EM, CXX GT3 Touring Adventure
Old 06-26-2024, 01:29 PM
  #76
M3Inline6
M3Inline6's Avatar
Received 1,981 Likes on 1,050 Posts
Originally Posted by dixonk
Probably be easier to just pull the gauge face off and transplant it to your panel.
That’s what I was thinking. It’ll be interesting to see how the gauge cluster modification plays out. I, too, love the S/T cluster as well.
Old 06-26-2024, 01:32 PM
  #77
f4bones
f4bones's Avatar
Received 1,304 Likes on 506 Posts
Not sure - I might use this for my Carrera S based GT2 as the Carrera cluster doesn't have the cool simplified displays that the GT3 / ST does. This has different software, but also not sure it talks to the other boxes nicely. It will be a good experiment. I will attempt to repair this one, but if I run into software issues, or the displays don't work, I'll just use the face . . .
Old 06-26-2024, 01:36 PM
  #78
M3Inline6
M3Inline6's Avatar
Are you referring to the simplified digital displays like our ‘22-up Carreras have?
I would love that face. Have you swapped the faces before?
Old 06-26-2024, 01:38 PM
  #79
f4bones
f4bones's Avatar
Yes, but the GT3s have a better presentation - my TTS also has the simplified display, but it doesn't show much info. The GT3 has TPMS display, and the necessary engine temps - also the has the shift ladder lights in PDK manual mode, which is very cool.
dixonk (06-26-2024)
Old 06-26-2024, 01:43 PM
  #80
M3Inline6
M3Inline6's Avatar
Ah ok! I’ll have to see what my simplified displays show. I tried them out when I first bought the car, but I never really used them.
Old 06-26-2024, 04:42 PM
  #81
Tobeit
Tobeit's Avatar
Received 1,516 Likes on 744 Posts
agree, i took my entire center gauge apart to replace the color ring and you can move the entire interior to a working gauge and panel.
Old 06-26-2024, 05:31 PM
  #82
f4bones
f4bones's Avatar
yeah - no question the gauge face can be swapped, but I want to retrofit the GT3 - S/T functionality / displays into the Carrera S body that will become my GT2 Clone . . . unknown at this point if the GT3 / S/T dash software will play nice with the other systems. We will find out thought!!
Old 06-26-2024, 05:34 PM
  #83
dixonk
dixonk's Avatar
Received 1,802 Likes on 801 Posts
It would be nice to have the shift lights of the GT3 and tire temperature display from the Carrera. Still unsure why a GT car wouldn’t have tire temps but a Carrera does.
Old 06-26-2024, 06:40 PM
  #84
f4bones
f4bones's Avatar
Yeah - total mystery why the GT3 doesn't have tire temperature - every other 992 I've seen has it (Carrera, TTS). . . same TPMS sensors - have to check to see if the receiver is the same. I suspect it's just a software issue.
Old 06-26-2024, 06:45 PM
  #85
M3Inline6
M3Inline6's Avatar
How easy was that process?
Old 06-26-2024, 07:01 PM
  #86
Shogunade
Shogunade's Avatar
Received 2,137 Likes on 1,183 Posts
Cause the code to do it requires an extra byte and consequently weighs an extra .01 gram.
Old 06-26-2024, 07:07 PM
  #87
f4bones
f4bones's Avatar
more like "the perception of 1 byte of code" would make the user "feel" like the car is .01 gram heavier . . just like the "perception" of a heated steering wheel makes the car feel less GT3ish. The Porsche Gods have spoken, now F'ing OBEY.
Old 06-26-2024, 11:09 PM
  #88
dixonk
dixonk's Avatar
It has to be in multiple locations or I missed something somewhere. I tried turning tire temps on in kombi but it didn’t show anything on the cluster. I will revisit this again tomorrow when I hook up PIWIS to switch the seat module out and write up a definitive seat memory install. Looking for code to put the command for comfort seats in PCM.
Old 06-26-2024, 11:14 PM
  #89
f4bones
f4bones's Avatar
For comfort seats - you might just need to autocode your PCM after your changes to maintenance of vehicle data to reflect memory seats. When I was coding in the folding mirrors, i was looking for something similar - IE fold on lock check box in PCM. Once I got the mirrors working, I autocoded the PCM, and it magically showed up. One thing to try with the Kombi and PCM - after you code, power down for a few minutes, and power back up - I've had to power cycle a few times to get code to take when coding. . .
dixonk (06-27-2024)
Old 06-27-2024, 08:21 AM
  #90
dixonk
dixonk's Avatar
Weird how it works sometimes. I turned on comfort windows and it showed up in the PCM. That’s why I thought comfort seats might have another item somewhere. Sitzmem Fahrer and Tuer Fahrer is where the seat memory options are.
Quick Reply: My DIY 992 PTS, EM, CXX GT3 Touring Adventure
