Has anyone tried to stick it on the back of the rear view mirror? FWIW, I tried on the underside of the frunk lid. Did not read it.
I painted mine black and it is behind the mirror on the windshield. But have you looked into the readers that attach to the front license plate (if your state has a front plate)?
I use the same cover. Although attached to the windshield off to the right a bit. It's tough to see from outside the car, mounted up high and totally blacked out.
There was a poster who used the contents inside the plastic holder and placed it within the mirror (???). Think it may be in the what did you buy your 992 today.
i like this idea. pretty slick. i painted mine matte black and replaced the clear double sided tape with the black stuff then put it on the windshield just below the mirror. not totally invisible but sticks out far less than the white
Thanks to you f*ckers I looked up where I mounted it and it gave me pause. After a rabbit hole of googling, this is what I found to be the best solution so far.
That was my post but I like shogunades post above better.
Took it apart and the chip is only 20% of the volume of the IL iPass. I tucked the contents above the passenger mirror. Worked fine in the targa, even on the skyway which I find particularly error prone.
