EZ Pass placement
That was my post but I like shogunades post above better.
Took it apart and the chip is only 20% of the volume of the IL iPass. I tucked the contents above the passenger mirror. Worked fine in the targa, even on the skyway which I find particularly error prone.
https://rennlist.com/forums/992/1162...l#post18852543
Thats fine if you never leave your state…. Not every EZPass state has access to plate data. IL in particular warns their EZPass users that they do not share plate data with other states so you still need a tag if you go out of state.
The following 2 users liked this post by Radiationman:
dg108 (09-07-2023),
Master Deep (09-07-2023)
Also, in Illinois, if they read your plate and not your transponder too many times in a month....1.) They will start charging you the cash price. (2x the ipass rate) 2.) After they get tired of charging you the cash rate they will start fining as well.
alin2 (09-07-2023)
If you have an iPass account and register for Pay By Plate they won’t charge you the cash rate or fine you - for tolls in IL only. IL Pay by Plate only works in IL with an iPass account - it doesn’t work with an EZPass account in any other state.
The Amazon product, referenced earlier and which I had in my 991.2, uses black Velcro which keeps the tag pretty hidden from outside. Could mount using Velcro to the back of the rear view mirror as well, similar to the approach shogunade posted about. Although in that one, the tag exterior is stripped away making it smaller.
That's a great idea and think it would work. When I did the wiretap trying to snake the wire in the best way, I didn't find a lot of room in there. Also noticed there is a side that needs to face "UP" . Hard part, it's not easy to test and I do belive different toll stations haslve different sensitivity. My CL I mounted on top of the shade for the moonroof and I get IL warning at a few booths but not all.
Mines in my center console. I take it out and hold it when I need it. its too ugly to stick anywhere visible.
The following 4 users liked this post by inthesticks:
EZ Pass is under the mirror, I cannot see it at all except from outside the car.
PHX (09-10-2023)
The following 2 users liked this post by PHX:
Scott P (09-25-2023),
tourenwagen (09-24-2023)
The following 6 users liked this post by Mrcleanr6:
bingjeep (09-27-2023),
Just J (09-24-2023),
Mike Murphy (09-25-2023),
mikey94025 (09-26-2023),
tourenwagen (09-24-2023),
and 1 others liked this post.
What material did you print that in? I've been concerned about putting anything made with PLA in the car because of the low melting point, and I don't have a safe space to print in ABS.
